Browse Forums Building Standards; Getting It Right! 1 Mar 06, 2016 7:49 pm Re: Whats the standard for placement of a solar hot water sy 2Mar 06, 2016 9:20 pm Well, if you wanna get technical, the purpose of the high window is so that the window isn't looking into the roofspace. It does look pretty crap, but I dont know if there is any standard for this issue. Re: Whats the standard for placement of a solar hot water sy 3Mar 07, 2016 5:57 am rebuilder86 Well, if you wanna get technical, the purpose of the high window is so that the window isn't looking into the roofspace.It does look pretty crap, but I dont know if there is any standard for this issue. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is where the hot water is referred to in the plan Re: Whats the standard for placement of a solar hot water sy 4Mar 07, 2016 11:08 am So the draftsman didnt plan it in front of the window then??? Is W10 the window we see in the picture? I thought that cabinetry in the pic looked like a kitchen not a bedroom???? Thats not right, it cant be that, that window 10 sais 1.8 by 1.2m. That's not the same window. Re: Whats the standard for placement of a solar hot water sy 5Mar 07, 2016 10:36 pm If it's a roof mounted tank, wouldn't it be shown on the roofing plan? Often the siting for these is related to roof shape/size and optimal north facing aspect. I think the plumber often has to make the final decision about exact placement too. Re: Whats the standard for placement of a solar hot water sy 6Aug 05, 2016 2:38 pm Could you please provide the top view(I prefer a photograph) of you roofing The more you feed your mind with positive thoughts, the more you can attract great things into your life the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12545 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20220 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24140 |
