Browse Forums Building Standards; Getting It Right! Re: Insulation q 21Jan 31, 2016 12:46 pm Sorry I meant roof, Please Leave a PM,Thanks Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Insulation q 22Feb 02, 2016 7:33 am Leksie5000 Thanks for your reply. Well the drawings weren't amended it was a correction they did on site after it was identified that there was an error in the drawings. An engineer etc didn't sign off on the changes as far as I am aware and not sure if one should have perhaps. Does such an error represent a breach of the BCA? What do you suggest I do follow bim guys advice above? Fortunately my cousin is a highly skilled engineer and she can probably have a look in the first instance. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Proper procedure should have been to amend architectural drawings then send them to engineer for review. Once review is completed (with changes if any) drawings are forwarded to Building Surveyor for amendment of building permit. Once stamped revised drawings are distributed. Your builder should know and follow proper procedure. Failing to follow approved drawings is a breach of warranties. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulation q 23Feb 02, 2016 7:46 am The building Surveyor is just a messenger, he will look at what he is told to look at and nothing more, nor is he qualified or able to pick out engineering mistakes, missed or incorrect details,etc,etc..mate you are not an engineer! Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Insulation q 24Feb 02, 2016 8:41 am Yeah that's exactly what worries me. His report listed the need for grip connectors in that area? But also said it varies slightly from the engineer detail. We are paying the builder to construct per engineer detail? Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Insulation q 25Feb 02, 2016 9:07 am Leksie5000 Yeah that's exactly what worries me. His report listed the need for grip connectors in that area? Yes it should be checked by an engineer, LOL Triplegrips for N2 -> a flat truss roof->Timber Frame Walls?....pull the other leg it's got bells on. Leksie5000 But also said it varies slightly from the engineer detail. We are paying the builder to construct per engineer detail? YES, please contact your engineer he is ultimately responsible. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Insulation q 26Feb 02, 2016 9:48 am StructuralBIMGuy The building Surveyor is just a messenger, he will look at what he is told to look at and nothing more, nor is he qualified or able to pick out engineering mistakes, missed or incorrect details,etc,etc..mate you are not an engineer! You seem to have problem grasping simple concepts. In Victoria Building Surveyor interprets and administers building control legislation, not engineers BS does not have to be an engineer and relies on engineering design that is peer reviewed and certified with Form 14 Your rant has no point. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulation q 27Feb 02, 2016 10:02 am I also suggest you lodge a complaint over your VBS incompetence with the Victorian Govt authority it's obvious your building System is Broken. BTW, IMO the home builder should select the engineer for peer review (if required?) and definately for the final inspection ..no use wasting any more of the average punters money with unqualified structural inspections by the VBS.hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11397 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6351 |
