Browse Forums Building Standards; Getting It Right! 1 Jan 08, 2016 3:15 pm Hi Everyone Were building in WA and noticed our ceiling joists that attach to the 31 courses aren't dyna bolted to the wall, it just has bits of pine joined to the roof. Our previous builds have been bolted and im wondering if anyone knows the standard/regulations around this? Some of the joist span over 4m and only held up by the nailed timber for support. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Ceiling Joists not dyna bolted? 2Jan 10, 2016 9:27 am Hi Durance3 Unfortunately your photos are missing critical details in order to make the correct call But from what i can see in the above it is non compliant 1. the fixing plates are nailed to the wall? 2. How are timber hangers attached to the ceiling fixing plate are they nailed (as I don't see any straps?} combining inadequate/ inferior fixing methods doesn't equal the correct method, this is often a misconception on site, the builder will need his engineer to certified that the above is equivalent or better than what is required. I also suggest you have the whole roof checked out. Please leave a PM Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Ceiling Joists not dyna bolted? 3Jan 10, 2016 10:31 am http://i1175.photobucket.com/albums/r631/abigail_cox1/P1030272_zpsqroamxix.jpg This is the same all around the raised ceiling areas. Re: Ceiling Joists not dyna bolted? 4Jan 10, 2016 10:59 am Quite often fixings such as dynabolts, straps, brackets are not delivered, missing, incorrectly used, misplaced etc,etc. 1. I cant see hanger straps? 2. Have the nail fixings cracked the timbers? etc,etc Again you will need to have it properly checked and you'll need an Engineers Certificate Stating " Fit For Purpose". Thanks for the photos I might add the purpose is to support the ceiling Dead loads and a tradesman + toolbag Live loads. It is the tradesman that will sue should he get injured Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5834 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14635 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 16829 |
