Browse Forums Building Standards; Getting It Right! 1 Dec 14, 2015 1:19 pm Hey All! I'm hoping someone can provide some advice here. I've had a house built and the rear of the slab comes within 40cm of a stormwater easement, however sits approx 90cm higher than the easement level. The builder simply banked up dirt against the back of the house to support the slab (See photo). The red marker shows the easement and you can clearly see the dirt built up behind the marker. Now the council is telling me that NO earth can overlap the easement, and the banked dirt must be removed - however this will cause slip from under the slab. Building a retaining wall will require approvals, exemptions and dollars as it's within 1.5m of a construction. So the question is - is this just bad luck for me, or should the builder bear some responsibility? What should I do moving forward? I should note - the photo was taken during construction. The house is full completed now and I've been in for a few years. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building at Warner Lakes in sunny Queensland. Building with Bold Properties. Building thread is here! - https://forum.homeone.com.au/viewtopic.php?f=31&t=38957 Blog is here! - http://campoutforland.blogspot.com my suspicion - some builders, they do usually make 'odd' settings in their site plan / pricing as their standards - being hopeful that first - the initial price is… 9 2482 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 |
