Browse Forums Building Standards; Getting It Right! 1 Nov 16, 2015 11:37 am I am building a room which is 6 x 4.4m. The walls are timber stud and will is being built under an existing patio. What I need help with is timber sizes and options. Can I span the 4.4m width with a joist without a hanger or cross batten Or do I need a hanger or go with a smaller joist and use a hanger. I guess the cheapest alternative is the winner. What size and grade timbers would I need and in what layout? Thanks. Oh and I plan to do it at 600mm centres. Re: Ceiling joist timbers 2Nov 23, 2015 12:09 pm HI extra_g, You will need a lot more detail if you wish to get any meaningful answer to your question. Also you need a permit for structural changes and those doing the drawings for that permit would have to visit site to ascertain which table to use in the light timber framing code or similar structural manual, Cheers Re: Ceiling joist timbers 3Nov 23, 2015 12:54 pm Hi extra_g You will need a structural engineer to certify the design/drawings, please check with your Local council Building Dept. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31831 Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9069 1 10134 |
