Browse Forums Building Standards; Getting It Right! 1 Nov 12, 2015 5:18 pm Hi all, Eaves and cornice boards got wet with heavy rains because of the Open roof tiles in our house. Question, eaves are now soaking wet. We are a bit concerned about this. Obviously they will dry, but will the fact they have gotten wet cause any problems? We are also expecting more rain, so they will get even more wet and remain wet for a while until the rain clears up completely. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Re: Eaves plaster board and cornice board got wet with heavy 2Nov 12, 2015 6:15 pm Mel sydney Hi all, Eaves and cornice boards got wet with heavy rains because of the Open roof tiles in our house. Are you sure the tiles are the problem? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Eaves plaster board and cornice board got wet with heavy 3Nov 12, 2015 6:24 pm SaveH2O Mel sydney Hi all, Eaves and cornice boards got wet with heavy rains because of the Open roof tiles in our house. Are you sure the tiles are the problem? They haven't removed roof scaffolding yet and open roof tile area around the house. The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should… 8 8486 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7847 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5869 |
