Browse Forums Building Standards; Getting It Right! Re: Sewer inspection points 2Nov 06, 2015 8:49 pm The plumbing code says: "provide adequate access for maintenance of mechanical components, operational controls and for clearing blockages" Basically that means an inspection point at any significant change in direction. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Sewer inspection points 7Nov 07, 2015 6:28 am goody59 Crazyk Geezus well I don't have any It is usually close to the main sewer connection and mine looks like a screwed down lid. But that one goes down to the jump up. It's nearly 20m to my closest toilet from there Re: Sewer inspection points 10Dec 07, 2015 12:53 pm Any idea on how the location of the sewer inspection point determined? I'm building a house and the builder has located the sewer inspection point in the middle of where the driveway will be laid. I'm asking the builder to move on another location but they are now saying it will cost me. I assumed that this was part of the onsite costs. Any advise on this is much appreciated. Building Sheridan 34 (38 after upgrades) @ Kellyville, NSW Check out our Clarendon Building Progress Blog Homeone Topic: Clarendon Casadream Build Re: Sewer inspection points 11Dec 07, 2015 1:33 pm The builder is pretty much right although if I was building your place it is one of the things I would have picked up when I'd get a sewer diagram from Sydney Water for your block pre - final contract. $20 and all the info is there. I do exactly the same when a client asks me to draw plans for them - reno or new house. And yes, as per Bashworth. It may or may not be in the NCC/BCA or AS, I'm unsure but installing an inspection opening at every change in direction comes under the "good trade practice " umbrella. One of these or at a Y junction etc http://www.pipeonline.com.au/listProduc ... ON+OPENING Stewie Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6485 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13825 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11669 |
