Browse Forums Building Standards; Getting It Right! Re: Fixing timber frame to concrete slab 2Sep 25, 2015 8:57 am Hi Wesky AS1684.2 Residential Timber framed construction You will also need to take into Account wind load (uplift) Codes AS 4055 & Structural Engineers Certification Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Fixing timber frame to concrete slab 3Sep 25, 2015 9:09 am Thanks!! Am I on the right track at this website http://www.timber.net.au/index.php/timb ... ng-as1684/ Re: Fixing timber frame to concrete slab 4Sep 25, 2015 9:18 am Answered my own question. I'm guessing nails are not bolts and nails going through the bottom plate into the concrete slab is not an efficient method of fixing the frame to the slab. Another thing to add to the defective list haha ohhh builders make me laugh. Re: Fixing timber frame to concrete slab 5Sep 25, 2015 9:28 am wesky Answered my own question. I'm guessing nails are not bolts and nails going through the bottom plate into the concrete slab is not an efficient method of fixing the frame to the slab. Another thing to add to the defective list haha ohhh builders make me laugh. Correct...I do structural Repairs on site and I can assure you clients don't see the funny side of finding defects years later when out of warranty. Also check your drawings for wind loading N1,N2,N3 etc, and get onto it quickly..BTW photos do help. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Fixing timber frame to concrete slab 6Sep 26, 2015 5:27 pm wesky Answered my own question. I'm guessing nails are not bolts and nails going through the bottom plate into the concrete slab is not an efficient method of fixing the frame to the slab. Another thing to add to the defective list haha ohhh builders make me laugh. Thats not entirely correct. Typically where there is a bracing panel, then bolts or chemical anchors will be required. If it is simply fixing the wall to the slab where there is no bracing or additional tie down required then yes nails through the bottom plate into the slab are all that is required. Re: Fixing timber frame to concrete slab 7Sep 28, 2015 8:04 am mgilla wesky Answered my own question. I'm guessing nails are not bolts and nails going through the bottom plate into the concrete slab is not an efficient method of fixing the frame to the slab. Another thing to add to the defective list haha ohhh builders make me laugh. Thats not entirely correct. Typically where there is a bracing panel, then bolts or chemical anchors will be required. If it is simply fixing the wall to the slab where there is no bracing or additional tie down required then yes nails through the bottom plate into the slab are all that is required. Sorry, what is bracing panel? 2014 30/05 $3900 25/08 Contracts 02/10 DA submitted 2015 17/02 DA approved 02/04 Colors 10/04 Demo 09/07 Construction start 27/07 Fill 15/08 Slab 21/09 Frame 2016 08/01 Bricks Re: Fixing timber frame to concrete slab 8Sep 28, 2015 8:28 am Hi Fisher75 Light structural frames are subject to a number of failure possibilities: 1. Buckling 2. Load reversals 3. Fatigue 4. Vibration, stress, shear, bending,excessive defections....etc Correct bracing design is imperative in above cases and in simple cases is dealt with in the codes The Australian Standards requires engineers to check & Certify these, if Designers and builders fail to deal with basic standard code compliance, (eg If the build is not in compliance with AS) then Engineer Certification is required stating that it is equivalent or better than what is required in the code, or provide remedies (fixes) for non-compliance. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Fixing timber frame to concrete slab 9Sep 28, 2015 4:10 pm Fisher75 mgilla wesky Answered my own question. I'm guessing nails are not bolts and nails going through the bottom plate into the concrete slab is not an efficient method of fixing the frame to the slab. Another thing to add to the defective list haha ohhh builders make me laugh. Thats not entirely correct. Typically where there is a bracing panel, then bolts or chemical anchors will be required. If it is simply fixing the wall to the slab where there is no bracing or additional tie down required then yes nails through the bottom plate into the slab are all that is required. Sorry, what is bracing panel? Bracing panels are typically ply or fibre cement sheets nailed to the wall frame. They can also be metal straps or angles fixed diagonally to the frame. At each end of the brace the wall needs to be tied down to the slab, this is normally done by screw in bolts, chemically secured bolts or in some cases hardened concrete nails. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8041 Thanks Pulse, thats really helpful and very much appreciated. Also thanks for the pointer on sheathing, thats me watching too many american youtube videos! 6 2812 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9568 |
