Browse Forums Building Standards; Getting It Right! 1 May 31, 2015 5:04 pm Hi Everyone I was wondering if anyone would be able to help me on building standards for balconys? My house was built in 2009, and I have recently noticed the balcony leaking down into the to potico at my front door. I've had the silicone (chaulking) along the edges of the tiles redone and also requested the builder to come out and look at it. The builder said it was leaking because of the silicon coming apart. The tiles have since lifted and the grout is starting to have cracks. I asked a balcony repairer to have a look and he said the waterproofing has failed and it will cost about $8K to have it repaired and that the builder should be fixing it. Can someone please tell me the BCA requirements for balcony waterproofing? Thanks Re: Leaking Balcony 2Jun 01, 2015 12:57 pm There arent any requirement unfortuantely. Unless there is a habitable living area underneath it. Your best bet is to riip up the tiles urself, waterproof it, then pay a tiler to re tile! Sorry that really is the best suggestion, i know it sucks! Re: Leaking Balcony 3Jun 02, 2015 8:54 am Waterproofing is waterproofing no matter if there is a habitable room under it or not. If it was part of the original contract drawings then standard builders warranty should apply which in NSW is 6 years from memory. Contact the NSW Dept of Fair Trading. Stewie Re: Leaking Balcony 4Jun 02, 2015 9:22 am Leaking balcony is defective workmanship (unless you have interfered) and subject to builder's warranty which in Vic is up to 10 Y Unless builder is willing to rectify you will need your own inspection report and make a claim in the tribunal. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaking Balcony 5Jun 02, 2015 6:58 pm u adamant of that stewie? I remember reading (although not state specific) that waterproofing regs are different from requirements of where waterproofing regs must be adhered to, and that balconys are practically allways exempt because they are outside. (in basic terminology) Re: Leaking Balcony 6Jun 02, 2015 9:33 pm Thank you for your replies I contacted Consumer Affairs Victoria today and was advised that a leaking balcony is due to the failure of the water proof membrane and I am covered by my builders warranty. I am contacting the builder again and will be lodging a complaint it they do not fix it. Thanks again! Re: Leaking Balcony 7Jun 04, 2015 8:48 pm angel Thank you for your replies I contacted Consumer Affairs Victoria today and was advised that a leaking balcony is due to the failure of the water proof membrane and I am covered by my builders warranty. I am contacting the builder again and will be lodging a complaint it they do not fix it. Thanks again! Let us know how you get on. 'It's not the size of the dog in the fight, it's the size of the fight in the dog.' DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 4780 Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours… 4 3755 |
