Hi all,
In a standard build which trade does the render clean up/sand before painting.
Edges are not sharp, surface is not smooth and some corners are chipped.
1 coat of paint done already.
Thanks
Browse Forums Building Standards; Getting It Right! Re: Sanding render before painting 2May 26, 2015 9:30 pm when you say render, do you mean cement render outside? or cement render inside before plastering? Re: Sanding render before painting 3May 26, 2015 9:35 pm Thanks, yes I'm talking about external render. I can't fault the inside plastering (white set). External is very rough - I'm surprised the painter put the 1st coat on luckily SS agrees and is getting it fixed. Re: Sanding render before painting 4May 26, 2015 9:46 pm oh dear, well you will have to take some action yourself here to protect your investment.... Ensure they understand that they can not patch this with a cementitious product now. They must use an acrylic modified patching compound as the paint has already coated the cement. That is quite odd, perhaps it was the junior apprentice or he was just having a bad day. Painters dont really like to put their product onto poor work.... so they will often take it upon themselves to repair minor issues with the grinding stone and patching compound. It is the painter who will cause further problems if they ignore the imperfections and just simply start painting, so in this situation its the painters fault. Re: Sanding render before painting 5Jul 24, 2015 9:08 pm Broken corners and major chips have to be fixed by a renderer, but sometimes painters do it as well. However, sanding of the render MUST be done by the painter, that is part of preparation work. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5152 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8579 |
