Hi all,
Hope someone can help out. Brickwork has started. We went to inspect today and saw a lot gaps between the bricks (no mortar) and wonder if it is acceptable by the Australia building standard code. Our neighbour just had a meeting with his site supervisor and he said that the plaster will cover it up (I think it is called white and grey float). Still, I feel like it is a sloppy job of not using enough mortar. Am I wrong? Here are some examples.
Our wardrobe:
If you zoom in, there is missing mortar for all vertical layer between bricks.
One of the corners. You can see it from the outside as well.
