Browse Forums Building Standards; Getting It Right! 1 Nov 03, 2014 6:39 pm The subframe of my decking currently blocks the first 10mm of the weepholes on the front of my house. Once the 20mm decking is installed, you can imagine that the first half of that row of weepholes will be covered. Thoughts? Re: Standards around decking blocking weepholes 2Nov 04, 2014 7:20 am Not a good idea. They are restricting where excess moisture that finds its way into the cavity can escape not to mention that they will be causing a potential termite ingress point. Stewie Re: Standards around decking blocking weepholes 3Nov 18, 2014 10:37 pm I was told to leave at least a 20mm gap between the house and the deck to allow for termite inspection, at least, that's how I'll be building my deck. Instead of using a ledger board against the house, I'll be putting an extra bearer attached to ground stirrups, and the joists will be slightly cantilevered I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 477 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10940 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6986 |
