Browse Forums Building Standards; Getting It Right! 1 Oct 16, 2014 7:51 pm Hi, We are DIYing our kitchen this Dec/Jan and wanted to know what we need to look out for, especially behind the oven and sink. The house is in NSW, if that helps. We'll be getting an electrician in for the electrics, and plumber (not for the electrics). What are the relevent standards and where do I find them? Can someone translate them into plain English? Thanks in advance for any help. Today is under construction. Thank you for understanding. Re: What do we need to know about kitchens? 2Oct 19, 2014 8:05 am Given the absence of replies I'll start posting my own research. Hopefully someone can correct me if I'm wrong. 600mm of vertical clearance to a combustible surface, and 200mm of horizontal distance to a vertical surface. If these measurements can't be met, the surface in question must be protected with a fire resistant material in accordance with AG/601. 600mm to a rangehood 750mm to an exhaust fan. horizontal clearance from a hotplate or burner to a vertical combustible material (like an acrylic splashback, for example) should be over 200mm. If not, the splashback or other material needs to be protected with a non-combustible material to a height of 150mm for the full length of the cooker -so tiling should be fine. Does cement board have to go behind the oven, under the tiles? Today is under construction. Thank you for understanding. Re: What do we need to know about kitchens? 3Oct 19, 2014 9:00 am HB 111-1998 The Domestic Kitchen Handbook Does anyone have a pdf share copy or know where it is being sold for a reasonable price? SAIGlobal is charging $95 for a pdf... I'm nott even sure if this is what I need as the preview is very limited. Today is under construction. Thank you for understanding. Re: What do we need to know about kitchens? 5Oct 19, 2014 9:23 am Reno, for sure. Today is under construction. Thank you for understanding. "is it exempt or do I need to get permission from council" Call your Council and ask them 1 1754 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 37172 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3902 |
