Browse Forums Building Standards; Getting It Right! Re: Framing Overhangs Slab 2Jul 07, 2014 8:45 am Not good at all unless they are going to do something about it before they clad the outside. Packing the bottom plate is one option. How much does it overhang ? Here is another thread about the same problem... viewtopic.php?f=38&t=70656&p=1162680&hilit=frame+overhang#p1162680 Stewie Re: Framing Overhangs Slab 4Jul 07, 2014 10:14 am The photo seems to show packing has been installed under the steel post. Packing should be provided under the overhanging timber. This is easy to do now whilst there is access to the outside of the wall frames. Re: Framing Overhangs Slab 5Jul 07, 2014 11:53 am Stewie D Here is another thread about the same problem... viewtopic.php?f=38&t=70656&p=1162680&hilit=frame+overhang#p1162680 Stewie Actually there lots of threads about this on here. Amazing how often this comes up. At least they are consistent! Re: Framing Overhangs Slab 7Jul 07, 2014 2:17 pm On my build I measured the slab after it was poured and then adjusted the drawings for the framing to match the slab. I still an overhand issue due to creep. It took me several walls before I realised what was happening and then I started making the frames 5mm shorter than the drawing. STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 5858 8 9904 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 16836 |
