Browse Forums Building Standards; Getting It Right! 1 May 01, 2014 1:59 pm we just discovered crack in PVC pipe which goes from stormwater drain (from downpipe) into soakwells - we discovered because we had a mini sinkhole where water sucked and eroded earth. The pipe is 80mm and runs along side of house into soakwell. It appeared where it cracked it was less than 200mm under ground level (top of pipe was 200mm from ground level). We had sand there and then compacted it and put cracked red gravel. We are not sure what could have caused it - it could have been faulty workmanship or due to landscaper - I would have thought the PVC pip would have been stronger to resist compacting. Are there standards on depth of these pipes as 200mm seems fairly shallow? I'm thinking of paving or concreting over that eventually - is there a way to ensure the pressure doesn't crack it again (assuming it wasn't a faulty workmanship issue). Bit concerned it could have happened elsewhere. On a related note, we have red gravel along back side of house - is it safe to have gravel next to house - potential drainage issues etc? Under 300mm of sand we're on fairly clay soil. Re: Depth of storm water drainage pipes 2May 01, 2014 2:43 pm Lines to be a minimum of 100mm under soil: 50mm under paved or concreted areas 100mm under unreinforced concrete or paved driveways 75mm under reinforced concrete driveways. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Depth of storm water drainage pipes 3May 01, 2014 4:27 pm ausdesign is correct. Unusual that they used an 80 mm DWV pipe. What State are you in? I'm guessing W.A. I would assume that a pipe draining to a soakwell still comes under stormwater regulations. The minimum pipe size for stormwater compliance is DN90. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Depth of storm water drainage pipes 4May 01, 2014 4:58 pm Sorry - I assumed it was 80mm at first glance, I should measure it properly. I'm going to get plumber out to inspect it and fix it in case there are bigger issues I can't identify. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7809 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6841 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10465 |
