Browse Forums Building Standards; Getting It Right! 1 Apr 09, 2014 4:01 am Will be installing a skillion roof, approx 1/30 fall to the rear of extension. my question is should the top plate of the framework on the end walls be up under the rafters following the same slope or fall? then install studs as usual. ty wobbly Design from top down to ground , build from ground up Re: framing to skillion roof ? 2Apr 09, 2014 5:50 pm Yes. With a low pitch (2 degree) that would be the way to go. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Why don't you call and talk with someone at the town planning in your council? 1 2184 STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 5860 8 9921 |
