Liliana
And if they say they have never heard of these rules or all of this is not necessary, don't listen. Better still, don't hire them.
As always, sage advice!
Browse Forums Building Standards; Getting It Right! Re: Protecting your Slab 21Apr 14, 2014 11:40 am Liliana And if they say they have never heard of these rules or all of this is not necessary, don't listen. Better still, don't hire them. As always, sage advice! 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Protecting your Slab 22Jul 10, 2014 3:17 pm Hi everyone I think I read a post somewhere or maybe my vivid imagination, that slab heave or crack due owner not following engineer’s specs and recommendation, the builder may not liable to fix? I was thinking of sourcing my own contractors to do the stormwater and paving, not the builder. My soil is classed E-D/P. I will definitely give these contractors the site drainage plans, engineering specs etc but whether they (or even to say the builder’s contractors) will follow it to the point. That is the question. cheers boosta http://boostaoakfordsa.wordpress.com Site works: 26/8/14 Trench: 2/9/14 Slab: 8/9/14 Frame: 18/9/14 Bricks: 24/10/14 2nd fix: 24/11/14 Handover: End Feb 2015 Re: Protecting your Slab 23Jul 10, 2014 6:56 pm boosta Hi everyone I think I read a post somewhere or maybe my vivid imagination, that slab heave or crack due owner not following engineer’s specs and recommendation, the builder may not liable to fix? I was thinking of sourcing my own contractors to do the stormwater and paving, not the builder. My soil is classed E-D/P. I will definitely give these contractors the site drainage plans, engineering specs etc but whether they (or even to say the builder’s contractors) will follow it to the point. That is the question. cheers boosta Once you do work you are the builder and the unintended consequence may be that you are letting your builder off the hook. Think about it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Protecting your Slab 24Jul 11, 2014 11:48 am Thanks BE! http://boostaoakfordsa.wordpress.com Site works: 26/8/14 Trench: 2/9/14 Slab: 8/9/14 Frame: 18/9/14 Bricks: 24/10/14 2nd fix: 24/11/14 Handover: End Feb 2015 Re: Protecting your Slab 25Jul 21, 2014 4:21 pm Quote: Once you do work you are the builder and the unintended consequence may be that you are letting your builder off the hook. Think about it. So how do you go about getting the apron around the perimeter. If they builder does not offer this service? but its recommended by their engineers? Re: Protecting your Slab 26Jul 21, 2014 6:29 pm Filthyfil Quote: Once you do work you are the builder and the unintended consequence may be that you are letting your builder off the hook. Think about it. So how do you go about getting the apron around the perimeter. If they builder does not offer this service? but its recommended by their engineers? I am a firm believer that builders who have not provided foundation protection to guard against slab heave or subsidence on reactive clay soils are negligent. If the engineer has recommended it and they did not follow engineering recommendation then that is the first nail in their coffin. This matter is yet to play out in VCAT and the courts so we will see how it develops. If builder has not provided foundation protection in your home then you have little option but to do it. Just make sure it is well done to required standard to avoid future finger pointing at you. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Protecting your Slab 27Jul 21, 2014 8:35 pm Filthyfil Here is a list (in no particular order) of precautions for those about to build to minimise the chances of slab heave.These are things that have contributed to slab heave in the past. Developers should avoid using highly reactive clay fill. The fill should be not over compacted and not dry of optimum moisture. This is obviously beyond the control of the home builder but check your soil report to see if you have fill over highly reactive clay .If you do then you are more susceptible to heave. The ground around the proposed slab area should be graded away to allow water to flow away from the footings. The ground should be scraped and not be built up to get this gradient, as water will flow through the built up fill and onto the foundation. Properly constructed agi/cut off drains must be installed the agi drain must be dug into the natural clay. The finishing depth must not be in the fill or topsoil diagram 1. Soil that is graded away from the footing or correctly sloping concrete should channel water into the agi/cut off drain or storm water inlet. A cut off drain will also prevent water ingress under the slab from neighbouring properties. See below http://i1028.photobucket.com/albums/y342/jmfieldwork1/IMG_3863_zps5f4aba87.jpg Concrete apron should be constructed around the perimeter of the house. This concrete apron must have a correctly sloping surface away from the house and into storm water inlets or spoon drain so that all surface water is collected and carried away in storm water pipes. The paving concreter must not do the plumbing; a qualified plumber should do all the necessary pipes and connections. The paving concreter must ensure that no existing pipes are crushed or punctured during concrete construction especially when using star pickets and when using machinery like bobcats. You should have eaves to protect your house from the weather and prevent rain from directly hitting your walls and running down onto your foundations. Your builder should ensure that the carpenters do not hard nail the plates between the top plate of your internal walls and the roof truss to allow for movement see below. http://i1028.photobucket.com/albums/y342/jmfieldwork1/IMG_0835_zps9151fef0.jpg The plumber should ensure that the pipe trenches slope is correct and the gradient complies with the Australian standards. The plumbing design should try to minimise the amount of plumbing under the slab and make sure that a clay plug or bentonite is used to prevent water from the outside travelling back up the plumbing trenches and under the slab. Flexible plumbing must be used on highly reactive soils. Before the house slab has been poured a full plumbing test should be performed video and pressure check and preferably again just before hand over. There must be appropriate number of downpipes to prevent overflow during storms especially if there are no eaves. During construction temporary down pipes must be used . Hot water unit must have overflow discharging into stormwater inlet. Air conditioners should have a connection to the storm water system. See below http://i1028.photobucket.com/albums/y342/jmfieldwork1/IMG_3862_zps829a1aae.jpg The house slab concreter must not allow over pour or blowout of the footings during slab construction this causes the load on the soil to be greatly reduced making the footings more susceptible to heave. All exposed decks/timber porches must have a roof or be cover to prevent water run between timber slates and ponding under the deck. The exposed deck will allow water in and prevent evaporation creating a wet area. Garden bed areas and veggie patches should be well away from the perimeter of the house. Garden sheds and covered small storage areas should be away from the perimeter of the house or have proper gutters and storm water connections. All connections for water tanks must be carried out by a qualified plumber and tested. Tank over flow must be connected to the storm water system. Discharged recycled water should not be used near the perimeter of your house. The effects of this type of discharge to the behaviour of the soil are not known yet. No sprinkler system should be close to your house including soakage hoses. Do not use landscaping quartz pebbles or cobbles around the perimeter of the house unless there is plastic sloping away from the house underneath it. Pebbles and cobbles allow the ground to be come soaked during the rain and prevent evaporation. See below. http://i1028.photobucket.com/albums/y342/jmfieldwork1/IMG_3860_zps4a097c32.jpg Protecting your Slab 28Jul 21, 2014 8:55 pm Is Slab heave applicable to Raft slabs? Obviously the deepened edge beams should stop water seeping directly under the slab. We are building on reactive clay and the soil report recommended M class on piers waffle but I requested a H class Raft slab and am paying extra for it. I don't know but I'm about old school. I think waffle is still "newish" technology for a price point and preferred Raft Re: Protecting your Slab 29Jul 21, 2014 9:02 pm Crazyk Is Slab heave applicable to Raft slabs? Obviously the deepened edge beams should stop water seeping directly under the slab. We are building on reactive clay and the soil report recommended M class on piers waffle but I requested a H class Raft slab and am paying extra for it. I don't know but I'm about old school. I think waffle is still "newish" technology for a price point and preferred Raft Raft slabs do heave but as you say the one thing in their favour is they can sometimes restrict water flow under the slab. You can still have slab heave even with piers.What is the reason for piers? Re: Protecting your Slab 30Jul 21, 2014 9:05 pm The piers were for the waffle because the site is classified P because of our KDR. I think from memory the soil report said the foundations had to bear down on the bedrock which is only between 700-900mm. That's a damn deep footing I would provide us some level of protection. Re: Protecting your Slab 31Jul 21, 2014 9:18 pm Yes they will stop settlement but not heave.You only have a thin layer of clay under your footings so p type based on a m type soil should be ok, the less clay under footing the less reactive the site will be.What area are you in. Re: Protecting your Slab 34Jul 21, 2014 9:42 pm insider Yes they will stop settlement but not heave.You only have a thin layer of clay under your footings so p type based on a m type soil should be ok, the less clay under footing the less reactive the site will be.What area are you in. Great list and great advice, the forum is fortunate to have someone with your experience I would just like to add that design guidelines for slabs on reactive foundations should include; 1 Assessment of prevailing weather walls (including two storey walls) and if necessary protection with roof structure such as pergola 2 Mandatory heave risk assessment ATTACHED TO EVERY SOIL TEST before land is released for sale with risk instructions to slab design engineer. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Protecting your Slab 35Jul 21, 2014 9:54 pm Thanks BE Good advice about pergolas in fact it maybe the only way to possibly reverse slab heave by allowing the ground to dry out and protect the slab from weather.Risk assesment is also a good suggestion. In Queensland during the soil test they take samples for lab testing which is the way we should be heading. I've been working on a assessment I'll see if I can find it. Re: Protecting your Slab 38Jul 21, 2014 10:15 pm It would add another $100-$200.But would slow down the reports by 1.5-2 weeks.The problem like everything in this industry is the big builders puts pressure on everyone to get the quickest and cheapest. Re: Protecting your Slab 39Jul 22, 2014 9:13 am Quote: By the way what is KDR Knock Down & Rebuild. Quote: I don't know but I'm about old school. I think waffle is still "newish" technology for a price point and preferred Raft I have to admit that just about every waffle pod slab I've seen pre-pour just doesn't look strong enough despite all the arguments to the contrary. Luckily the engineer I use and who will be looking after our build is old school too. We are in a different boat though as 99% of our build will be over rock ( which brings its own problems too in some ways ). Stewie Re: Protecting your Slab 40Jul 22, 2014 10:31 am Stewie D Quote: By the way what is KDR Knock Down & Rebuild. Quote: I don't know but I'm about old school. I think waffle is still "newish" technology for a price point and preferred Raft I have to admit that just about every waffle pod slab I've seen pre-pour just doesn't look strong enough despite all the arguments to the contrary. Luckily the engineer I use and who will be looking after our build is old school too. We are in a different boat though as 99% of our build will be over rock ( which brings its own problems too in some ways ). Stewie I think this is a classic example about theory and practice. Theoretically waffle slabs are just as serviceable as conventional raft slabs but in practice they are much riskier on reactive soils. Because waffle sits on level ground then if you have drainage leak against slab edge it has the potential to spread to a large area under the slab and cause soil heave,. Conventional slab that has edge beams excavated 100mm into natural clay will be somewhat protected better because edge beam will act as barrier to spread of water. I have seen a large 2 storey home on waffle completely tilted 100 mm out of level because of edge leak at rear of dwelling. Unfortunately for the owner he was interfering with drains and I think that builder is off the hook. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16322 4 6243 The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5224 |
