Browse Forums Building Standards; Getting It Right! 1 Feb 18, 2014 10:00 am Hi All Has anyone ever used masterwall before. A draftsman I have been talking too recomends it highly. He is designing steel framed homes clad in Masterwall. The product brochure seems pretty good. Has anyone any feedback please? cheers Re: Anyone used Masterwall before? 2Feb 19, 2014 10:27 am Masterwall is a good product that we nominated for the external cladding on several homes. The most common thickness used is possibly the 75mm sheet rated at R2.0 on a framed wall which also allows a framing cavity to include R2.0 or R2.5 batts for added insulation levels. The extruded polystyrene system is also good for upper storey extensions where a light-weight system is required. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Anyone used Masterwall before? 3Mar 05, 2017 9:59 pm Hello Peter, I am a newbie to HomeOne, but read with interest your comments with Masterwall. My Architect has specified 75mm Masterwall (direct to frame) with a 5mm render outside, and while I am aware of it's insulation properties, I am concerned about it's fire-ratings and ability to dent, as it is being used both at Ground and First Floor. The other point I wanted to make is that based on this the Engineer has allowed for a depth of 70mm below bottom plate for it to sit on the slab rebate. The soil is H1 reactive and we have bored piers with a concrete slab ??? I wanted your viewpoint of using Masterwall, as I have heard concerning comments regarding cracks in the render, water ingres and non-durability of the product; and from what I read here you have been using it since 2008 or so. I want to ensure therefore that my builder uses the right approach and I get a quality finish that does not require too much maintainance. Re: Anyone used Masterwall before? 4Mar 06, 2017 1:21 pm Hi mehram I couldn't find any relevant engineering Data and Details so I guess the jury is still out on similar newer products. Ive inspected, maintained & repaired previous lightweight Panel rendered/ Esky Homes before ..they are a nightmare to repair and maintain. Unfortunately there are no Australian Standards and you are rightfully cautious regarding newer building systems..more info is required in order to make an informed decision. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Anyone used Masterwall before? 5Mar 06, 2017 3:54 pm Thanks for your quick response StucturalIBIMGuy, I'm somewhat stuck as the Structural Engineering has already been done. What about using Hebel, is that mch better than EPS, or would you just stick to 'tried and tested' bricks and mortar? Re: Anyone used Masterwall before? 6Mar 06, 2017 5:33 pm mehram or would you just stick to 'tried and tested' bricks and mortar? Yep.. AS3700 masonry construction..... it's best to eliminate any doubt Builders & Engineers use standard cad details it shouldn't cost anymore to update your engineering. HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17786 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18280 Been in a similar position and we decided to let the builder go. Some of the PSA money goes to engineering so we at least got those documents and they actually refunded us… 2 6014 |
