Browse Forums Building Standards; Getting It Right! Re: Can you use liquid limestone to construct a wall in a ho 2Jan 27, 2014 9:46 am I don't see why not as Liquid limestone is really just a different sort of concrete. The differences are:
It uses crushed limestone rather than other types of gravel, and sand. Quite often a plasticiser is added. This means the mixture can be poured without having to add too much water. One of the issues with pouring concrete in a wall is getting rid of all the air. As I expect you will want a good surface finish you will want to make sure the concrete is well vibrated to minimise the air voids when you remove the formwork. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Can you use liquid limestone to construct a wall in a ho 3Oct 03, 2014 7:23 pm http://kezandgonzo.blogspot.com.au/ did you go ahead? In my blog above there are photos of our rammed earth home using crushed limestone Owner build - Perth Hills Earth works started June 2012 - almost lock up Oct 2014! http://www.kezandgonzo.blogspot.com.au Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 2980 2 10946 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20728 |
