Browse Forums Building Standards; Getting It Right! Re: Broken areas of barrier in pre slab . Is this OK? 2Jan 21, 2014 2:54 pm Not acceptable , it's poor workmanship Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Broken areas of barrier in pre slab . Is this OK? 3Jan 21, 2014 3:09 pm I think so too. What are problems down the track if the barrier is breached? Re: Broken areas of barrier in pre slab . Is this OK? 4Jan 21, 2014 4:17 pm You could get dampness in your slab Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Broken areas of barrier in pre slab . Is this OK? 5Jan 23, 2014 9:22 pm That doesn't look good, at least it would be an easy fix Re: Broken areas of barrier in pre slab . Is this OK? 6Jan 23, 2014 9:22 pm P.S. they are missing the termite collars too Re: Broken areas of barrier in pre slab . Is this OK? 7Jan 24, 2014 1:55 pm Thanks guys... I actually requested an inspection of the site on Wednesday. The builder emails me on the Thursday arvo saying they completed it already. I have a feeling they didn't want me to inspect pre-slab. Not impressed! Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3818 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9944 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15113 |
