Browse Forums Building Standards; Getting It Right! 1 Jan 06, 2014 2:51 pm Hi All I am looking at buying a block in a suburb that is on septics, but across the road in a new sub-division there is infil/deep sewage available. Now my issue is that this block is lower than the depth of the deep sewage line across the road and therefore I will need to build the block up about a meter or so in order to be able to gravity feed to the infil sewer line. I dont want to put septics in because the block is subdividable. Is there a vacuum wastewater product that is approved for use in Western Australia for a domestic application? cheers in advance!!! Re: Vacuum sewerage system 2Jan 06, 2014 3:07 pm Vacuum systems aren't suitable for your application. You may be better off with a 'Pressure Sewerage' Solution. See this link: http://www.eone.com/sewer-systems/regions/au/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Vacuum sewerage system 4Jan 06, 2014 9:23 pm Good link Brian. We had looked previously at a Saniaccess system to pump waste from our downstairs bathroom up about a metre to the sewer but this looks like it may be a better product. Do you know if they are available here ? Stewie Re: Vacuum sewerage system 5Jan 07, 2014 4:52 am They should be. I worked on a project to install about 200 in Central Coast NSW about 4 years ago. Both Mono Pumps and Flygt also have pressure sewer pumpss. . The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19473 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9767 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12126 |
