Browse Forums Building Standards; Getting It Right! 1 Oct 23, 2013 11:57 am Hi all, Just after some quick help. Building in WA with a "boutique" builder, in metro area. Coming up to our PCI meeting I'd guess in the next few weeks. We have a rear garage roller door, which we've measured to be 30mm less that the spec. Is this the normal, or are there certain allowances we should be considering?? Our problem is if it remains this much difference, it will be of no use to us, as we won't be able to put the trailer through to store in the backyard. When we originally questioned making this a wider entrance, they told us it would be fine as is (famous last words). We've contacted the builder, whose receptionist is quick to put us through to voicemail, but have had no callbacks/emails yet, even though we were assured they would 2 days ago. Re: Garage Entry - How much size difference is builder allow 2Oct 23, 2013 1:39 pm If the spec says the size that's what it should be. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Garage Entry - How much size difference is builder allow 3Nov 01, 2013 6:52 pm Thanks for the response. Thought this would be the case. Looks like this builder is now choosing to work to rule, today marking day 274 of our 300 working day contract, and the house has been sitting at Practical Completion stage for over 5 weeks now!!! Re: Garage Entry - How much size difference is builder allow 4Nov 02, 2013 7:35 am I agree that 30mm is way beyond any sort of normal tolerance. Is there any reason for the alteration? @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Garage Entry - How much size difference is builder allow 5Nov 02, 2013 9:35 am 30cm is massive I think and in your case it is the difference of being fit for purpose or not. I would stand your ground on this and possibly get and independent inspection to back up. If it is 30cm less does that mean they have bricked in too much? I would have thought so and that would also need to be redone. You could also ring master builders of some of the Perth regulating bodies to clarify what remedies you have as I think you would have insurance against this sort of thing, but I don;t know for sure. Good luck and please post the outcome. Cheers Mark Re: Garage Entry - How much size difference is builder allow 6Nov 04, 2013 7:21 am It's 30mm AM not 30cm which would be a huge difference to the opening ! Has the builder worked to full or half brick sizes rather cutting one column to suit the correct opening size ? Stewie Re: Garage Entry - How much size difference is builder allow 7Nov 04, 2013 9:56 am If 30 mm difference means that the trailer won't fit through, then the door was too narrow to start with. Who allows for less than a combined (both sides) clearance of less than 30 mm? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Garage Entry - How much size difference is builder allow 8Nov 04, 2013 10:14 am Is the brick work rendered? You will notice on the plans that it specifies that all dimensions are to brickwork, if it has been rendered then you will loose about 10mm each side sometimes more if the plasterer is straightening brickwork. This applies to overall room sizes as well. People sometimes forget that the dimensions are to brickwork and you will loose size in openings and between walls. I'd suggest that the opening was always going to be a bit tight for it's purpose. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Garage Entry - How much size difference is builder allow 9Nov 05, 2013 3:28 pm AM - yes, it's 30mm, not 30cm. I'd have hit the roof if this was the case. Stewie D - good q, will have to go back and check out the photos. From memory they didn't cut down any of the bricks, and were using full brick sizes, with the brickwork being some of the straightest I've seen. SaveH20 - 1.5cm clearance either side is perfectly fine for us. With 2 race cars, we've learnt how to manoeuvre. Chippy - yes, sorry, forgot to mention rendered. The 30mm above is after taking into account an estimated 20mm in render, so unless 25mm of render each side is acceptable (at least we know we can chip it away if we need to). Getting an independent building inspector to take with us to the Practical Completion meeting, whenever the builder chooses to contact us to book this, or return our calls. Called the Managing Director, and no surprises that he also isn't returning calls. So much for customer service. As you can all imagine, this is the least of our problems with this "premium" Perth building company. Streaky render and differing textures on bottom storey (had one of the biggest storms of the year within 20 mins of the renderers finishing), we can stick our hand through the top of the front roller doors and pull on the security wire (if we wanted to), so not waterproof, and the list goes on. Thanks all for your help. Feel more certain now that we were on the right path. Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6354 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11377 Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and… 0 3256 |
