Browse Forums Building Standards; Getting It Right! 1 Oct 09, 2013 10:31 pm I have a dropped edge beam on the left side of my slab (say RL 51.5). My garage level is higher (RL 52.0). So when I get a concrete driveway put in. Is it true that I cannot concrete above RL 51.5 where the dropped edge beam is? Re: Dropped Edge Beam 2Oct 11, 2013 2:16 pm A picture would probably help but if I am reading your question correctly then - if there are weep holes (damp proof course) then the finished level must be a minimum 75mm below & sloping away from the building. Deep rebates are often included on sloping sites but the dp course is generally one brick course down from the floor level. (On garages with single skin brick work the are no weep holes obviously) Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12873 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27310 |
