Browse Forums Building Standards; Getting It Right! 1 Aug 28, 2013 9:00 pm Hi all, Chasing opinions on my situation. Ill summarize briefly - Basically hot water system went kaput, called in a reputable plumbing service to do the replacement. Plumber comes around and inspects my set up, informs me my old system is too close to a bedroom window and needs to move the new system 50cm over to make it a legal installation. I was fine with that and paid the extra $ for the extra pipe work? Anyway, job went fine and couldn't fault the plumber, as a tradie goes he was top notch. So a few weeks later a gas rep calls to come and inspect the HWS install, fine no prob, until he tells my wife the system is now to close to the bathroom window on the other side... Plumber comes back and says he was under the impression the bathroom window was a fixed window and didn't open. Anyway we nut that problem out, and agree that ill get the bedroom window reversed so it opens on the opposite side and he will come back and move the unit back to its original place. Again great, until he goes on holidays and the company send another plumber. This is the install he did, http://postimg.org/gallery/7t5dzbj8/ I personally think its a bit dodge, but im not a plumber and would appreciate opinions. Thanks guys Re: Hot Water System plumbing problem 2Aug 28, 2013 9:32 pm It was probably lucky you didn't stand there too long or he may have run the pipe around your feet and back to the wall! . At least the bends are reasonably neat. I would get anotyher opinion about the pressure release valve which is now fitted remote from the unit? @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Hot Water System plumbing problem 4Aug 28, 2013 9:47 pm The pipes are no great problem except the inlet which is capable of being damaged because it is away from the unit. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13488 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
