Browse Forums Building Standards; Getting It Right! 1 Aug 15, 2013 10:40 am We are planning to get a storage gas hot water heater installed. The heater is a Aquamax 390 SS. I understand there is a requirement to have the gas hot water heat installed next to a wall. But on this particular wall, we have a huge storm water PVC pipe run across the whole wall. The pipe is 100mm radius. We can't move the pipe, otherwise, it go across one of my window, which will be super duper ugly. My plumber suggested one way to solve the issue is to attach some wood studs between the wall and the tank. Not sure if anyone has faced same issue before and what is your fix? Re: Storage gas hot water heater installation issue 2Aug 16, 2013 11:19 am Can you post a photo (not a close up)? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storage gas hot water heater installation issue 3Aug 16, 2013 11:24 am Or you could get some 125-150mm stand-off brackets made out of gal or stainless steel to fix your tank to. That heater I assume rests on a base so there is no weight carried by the brackets - they'd only be to stop it toppling over. I'm surprised the plumber didn't suggest something like this. Stewie Re: Storage gas hot water heater installation issue 5Aug 21, 2013 4:33 pm I don't understand why the downpipe doesn't drain into a stormwater connection immediately below it. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storage gas hot water heater installation issue 6Aug 21, 2013 4:37 pm SaveH2O I don't understand why the downpipe doesn't drain into a stormwater connection immediately below it. There is no obvious storm water drain underneath there. The gutter was re-done by previous owner. Have no idea how it was drained before. I suppose nail three piece of wood is way easier than digger through the mud to located the storm water pipe and then re-route the PVC pipe to it... I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 16079 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 11863 The time to heat is purely a function of the distance between the hws and the faucet. There are many options for hot water, you can also have a circulating circuit of hot… 1 8646 |
