Browse Forums Building Standards; Getting It Right! 1 Jun 06, 2013 5:18 pm I was wondering if somebody out there knows the answer to this problem .
We are trying to work out paving levels down the side of our house. We have found that if we want to keep the paving level all the way along, it means having to excavate below the fence line at the back because the fence was built by the neighbours to follow the contours of the land. However, if we do a step up in the paving to avoid excavating we end up with the finished paving level being flush with the bottom weatherboard at the back of our house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The finished floor level inside the house including the tiles is only 3cm above this bottom weatherboard. Is it alright to pave to this height? I'm thinking in particular of the requirement for 75ml of the slab to be exposed for termite inspections. Can anyone help out on this one or know of an alternative solution? Re: Paving levels and finished floor levels 2Jun 07, 2013 8:28 am Floor level to ground level is a minimum of 150mm but this can be reduced to a min. of 50mm where paving slopes away from the slab edge. This does not over-ride the termite required distance if you are using 'exposed slab edge' method. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Paving levels and finished floor levels 3Jun 07, 2013 8:52 am Thank you for that Ausdesign. I'm really puzzled though as to why the builder was allowed to leave our house with less than 150mm of clearance between the ground and the floor level as in below:
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The concreters have now paved right up under the weatherboards giving us about 30mm clearance between the floor and ground level and haven't even sloped the concrete away from the house. Why is that the only people who seem to know the building regulations are on this forum? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Paving levels and finished floor levels 5Jun 09, 2013 9:34 pm We have Granitgard. So we are supposed to leave 75mm of the slab exposed. But the ORG is the other problem. It is supposed to be 50mm above the paving and it isn't. Also it is now virtually at the height of our shower base! It looks like we are going to have to rip up the concrete and do it ourselves. Re: Paving levels and finished floor levels 6Aug 22, 2013 8:42 pm Hi guys Just wondering if anyone has exposed slab on their house. We have it on the right hand side of the house. (see picture) Anyone know whether this is ok or should I be worried? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Concerto w/ Ivy Facade Sep 12 Paid $3500 Oct 12 Revised Tender Nov 12 Final Plan Jan 13 Signed Contract May 13 Construction Start Jul 13 Slab Frame Aug 13 Roof Sep 13 Lockup Oct 13 PCI Nov 13 Keys interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46866 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6335 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10892 |
