Browse Forums Building Standards; Getting It Right! 1 May 21, 2013 9:48 am Hello, I cut 4 pieces of 1x4 wood - 2 pieces 10' and 2 pieces 10'1.5" to account for the 3/4" of the other 2 boards. After assembling with the 10' pieces across from each other and the two longer pieces on the opposite sides overhanging the 10' pieces I measured the diagonals - and guess what they are off by 2". So I remeasured and my boards are the sizes I planned for. So how does one cut boards and assemble to make a perfect 10' square? Or any square for that matter.... Thank you, from a distressed clueless newbie Re: How to build a perfectly square wooden form 2May 21, 2013 7:50 pm Easy. No saw cut will be square enough to assemble square over 10'. Your form needs to be levelled and staked into position before concrete is placed. Stake one side, push the frame until the diagonals are the same and put the other stakes into the ground. Re: How to build a perfectly square wooden form 3May 21, 2013 7:58 pm You always need to adjust the angles based on checking the diagonals, or Set up a simple right angle as follows Measure 4' from the corner along one piece of wood. Measure 3' from the corner along the other piece of wood Adjust the wood until the two marks are 5' apart and the angle will be 90 degrees The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to build a perfectly square wooden form 4May 22, 2013 3:24 am Okay, so if I'm hearing right my cuts were ok but my square wood form is a bit tweaked, and I should be able to push it right. I'll give it a try ~ Thank you I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3019 Depends... Brick veneer required the window to be attached to the house frame, this is usually achieved by screwing through the timber reveal into the frame. There are… 1 7433 No idea about the driveway question, but your price for a house that size including landscaping seems very good! 1 6126 |
