Browse Forums Building Standards; Getting It Right! 1 May 01, 2013 10:53 pm Hi all, I will check this with my council, but I was wondering can you usually build a wall on your front boundary, and have the eaves/gutter overhanging the boundary? Or must the gutter eaves also be within the boundary line? Thanks. Re: Boundary lines and gutter/eaves 2May 02, 2013 8:41 am You have to obide by the offsets in your street. The only way You'll be allowed to build right up to the foothpath is if there was an existing structure built like that. Even then if you pull down that existing structure the chances are you will be forced by council to obide by new offsets. Nothing can overhang on any boundary. If your building on the boundary in most cases there will be no eaves rather a parapet wall with internal box gutter. Re: Boundary lines and gutter/eaves 3May 02, 2013 9:41 am Sorry I didn't word it very well. We are allowed to build 2m from our side/front boundary (corner block). In this case would that 2m be to the wall, or to the gutter/eaves? Same case for the neighbour boundary, at a setback of 1m from the neighbour boundary we can build a wall 3.6m tall. Would that usually be to the top of the wall, or the top of any part of the structure (i.e to the top of the roof) at 1m setback? Re: Boundary lines and gutter/eaves 4May 02, 2013 10:57 am Your 2m offset is from the wall not from your roof line. Not quiet following what your second question is but in all cases your offsets are from the wall, not roof line. Re: Boundary lines and gutter/eaves 6May 02, 2013 1:03 pm [quote=" Same case for the neighbour boundary, at a setback of 1m from the neighbour boundary we can build a wall 3.6m tall. Would that usually be to the top of the wall, or the top of any part of the structure (i.e to the top of the roof) at 1m setback?[/quote] Top of the roof Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Boundary lines and gutter/eaves 8Jun 04, 2013 10:27 pm HouseOB - In Victoria, Typically Porches, pergolas and verandahs that are less than 3.6 metres high and eaves may encroach not more than 2.5 metres into your side street setbacks. (Standard A3 - Planning Provision 54.03). With your side / rear setbacks to your neighbour you are correct regarding the 1m setback for 3.6m height (typically), however Sunblinds, verandahs, porches, eaves, fascias, gutters, masonry chimneys, flues, pipes, domestic fuel or water tanks, and heating or cooling equipment or other services may encroach not more than 0.5 metres into this offset. Landings having an area of not more than 2 square metres and less than 1 metre high, stairways, ramps, pergolas, shade sails and carports may encroach into this setback. (Standard A10 - Planning Provision 54.04) These are all standard Rescode clauses, which can be found at http://planningschemes.dpcd.vic.gov.au/ Happy to elaborate if needed. The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7872 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4938 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8983 |
