Browse Forums Building Standards; Getting It Right! 1 Apr 07, 2013 6:20 pm Hi all, First time poster on here so would appreciate your help. I've bought an apartment off the plan which is due from completion in 4 weeks time. Had an inspection a few days ago and I was quite concerned with the gap between the edge of our balcony floor and the balustrade/perforated metal balcony. Just to make it clear, i'm not talking about the vertical gap between the top of the balcony floor surface to where the perforated metal starts. I'm talking about my tiles ending, then a gap, then the balony sheet of metal. I understand that 125mm is the standards but on the biggest gap i can fit my foot straight down. I'm concerned not only for potential of injury, but the fact that i'm going to drop so much stuff down that large gap. To make things worse, the concrete slab of the balcony ends and then the tiles run for an additional 55mm over the edges of the concrete slab. The biggest gap is around 90 - 100mm whilst the smaller gaps are around 70mm but with the 55mm of overhang from the tiles, it's quite a distance that isn't built to take loads e.g. pot plant, person. If someone could help with recommendations that would be great. I've suggested some white powdercoated angle to bridge the gap. I had no idea how to post an image so let me know and I will do so to help make it easier to answer my question. Thanks in advance. Thebigo Re: HELP NEEDED - Balcony gaps to the balustrade 4Apr 19, 2013 2:40 pm Hi I think the gap is not an issue for your builder if it is ≤ 125mm. But if the 125mm includes anything that would not withstand human impact (overhang) - I am testing some balustrade at this moment for exactly this - then the system does not meet the standard and needs to be fixed. If it was me... if it is tile overhang that brings it within 125mm, then tell the builder it needs fixing. If it is within 125mm then I would fit a box section of aluminium in anodised to the balustrade to cover the gap. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: HELP NEEDED - Balcony gaps to the balustrade 5Apr 19, 2013 3:42 pm ed @ ecoclassic Hi I think the gap is not an issue for your builder if it is ≤ 125mm. But if the 125mm includes anything that would not withstand human impact (overhang) - I am testing some balustrade at this moment for exactly this - then the system does not meet the standard and needs to be fixed. If it was me... if it is tile overhang that brings it within 125mm, then tell the builder it needs fixing. If it is within 125mm then I would fit a box section of aluminium in anodised to the balustrade to cover the gap. Ed Thanks for your input Ed. The overhang certainly increases the gap between balustrade and slab to >125mm however not including the overhang, surely if my foot can easily fit down that gap (and also a toddlers body), surely this isn't safe or fit for purpose??? Re: HELP NEEDED - Balcony gaps to the balustrade 6Apr 19, 2013 4:32 pm thebigo ed @ ecoclassic Hi I think the gap is not an issue for your builder if it is ≤ 125mm. But if the 125mm includes anything that would not withstand human impact (overhang) - I am testing some balustrade at this moment for exactly this - then the system does not meet the standard and needs to be fixed. If it was me... if it is tile overhang that brings it within 125mm, then tell the builder it needs fixing. If it is within 125mm then I would fit a box section of aluminium in anodised to the balustrade to cover the gap. Ed Thanks for your input Ed. The overhang certainly increases the gap between balustrade and slab to >125mm however not including the overhang, surely if my foot can easily fit down that gap (and also a toddlers body), surely this isn't safe or fit for purpose??? I agree with you, but it passes the standard. If it was mine, I would do as you say. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: HELP NEEDED - Balcony gaps to the balustrade 7Apr 19, 2013 6:12 pm Thanks Ed. I've notified the building conveyor, building commission and local council just so that my concerns are documented. It's now up to the developer and builder to work out if they will fix it or take the chance. Ill let you know how it pans out Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7581 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19320 Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 7103 |
