Browse Forums Building Standards; Getting It Right! 1 Apr 06, 2013 9:52 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Guide to Standards and Tolerances is Bible"Book of Excus 4Apr 13, 2013 11:04 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Guide to Standards and Tolerances is Bible"Book of Excus 7Apr 13, 2013 1:25 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Guide to Standards and Tolerances is Bible"Book of Excus 10Apr 14, 2013 5:03 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Guide to Standards and Tolerances is Bible"Book of Excus 12Apr 14, 2013 9:51 pm ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Guide to Standards and Tolerances is Bible"Book of Excus 13Apr 15, 2013 11:04 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Guide to Standards and Tolerances is Bible"Book of Excus 17Apr 28, 2013 10:59 am Where you are coming from is where you are going to... Re: Guide to Standards and Tolerances is Bible"Book of Excus 18Mar 20, 2017 9:21 am This is what I absolutely hate about Guide to Standards and Tolerances Australia's most professional builder is hiding behind the guide for entry door that is badly bowed and cannot seal when closed. Would the director of the building company accept this on his home? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 4726 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 4448 2 6449 |
