Browse Forums Building Standards; Getting It Right! 1 Mar 22, 2013 6:46 pm I am currently reading thru my contract specs - only made it to the first page, and I already have question, might be a long night ... It reads ' Our construction practices comply with the requirements of the National Construction Code 2012 (NCC), The tolerance values and standards of workmanship for all our building work undertaken is equivalent to the quality of the display home and as detailed in the NCC' Is this what it should read? I thought I was looking for the words "Australian Building Standards and Tolerances" Re: Dumb Question ... Standards of Workmanship 2Mar 22, 2013 6:56 pm From what I can read, the National Construction Code 2012 takes into account the Building Code of Australia. Regardless, A) the builder still has to comply to Australian Standards. The Australian Building Standards and Tolerances is just a summary of most of the relevant tolerances mentioned within each relevant Australia Standard. B) unfortunately sometimes the guarantee the builder gives is only as good as the paper it's written on. All in all, make sure you have done your research on the builder and you are happy with their history of producing quality homes. Building Standards; Getting It Right! Hi, yes, we have the report. The builder has rectified the items on the report and we’re moving forward with the build. Thanks for reaching out 2 2385 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5152 |
