Browse Forums Building Standards; Getting It Right! 1 Mar 22, 2013 10:28 am We have a Bonaire central gas heating unit in our ceiling space. It had a plastic pipe that went through the tiles and was capped on top. It looks a lot like a stink pipe (not sure what the correct term is). Previously, the exhaust (flue?) terminated above the ridge capping on our tiles. This week we had solar panels installed and the installers trimmed this pipe down to below the level of the panels. It now protrudes around 25mm from the roof, and has been cut off (i.e. not capped anymore). It is below one of the solar panels and has up to 50mm of space between the top of the pipe and the bottom of the panel. Can anyone with access to Australian standards tell me if the pipe must be above the level of the ridge capping? My concerns are as follows: - Not adhering to standards; Potential for warranty claim denial from heating company in the event of issues. - heat from exhaust pipe may damage panel; I have a picture below but it's not terribly clear. My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5126 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2980 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5944 |
