Browse Forums Building Standards; Getting It Right! 1 Oct 26, 2012 6:08 pm We are building a double storey house in Sydney with a Colorbond roof. Our builder says BCA only requires sarking and not ceiling insulation and is disputing that we didn't include it in the specs. I'm pretty sure this is a BASIX requirement. At the moment we only have sarking with a foil backed blanket which is R0.5. Can someone please tell me what are the requirements and minimum expectations of what the builder should provide to comply? Re: Ceiling Insulation requirements in NSW 2Oct 26, 2012 6:58 pm Insulation requirements will be stipulated on building permit drawings and in energy rating report for your house. Have a good look at your contract, inclusions and drawings. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Ceiling Insulation requirements in NSW 3Oct 26, 2012 7:53 pm In the BASIX Certificate under Thermal Comfort Commitment there is a line item for "ceiling and roof - flat ceiling / pitched roof". For this it says the Additional Insulation required (R-value) is "ceiling: 1.45 (up), roof: foil backed blanket (55mm)". The builder thinks this just refers to sarking and I disagree. There is no other mention of ceiling insulation in the contracts & inclusions however BASIX does form part of the additional documents referred to by the contract. Re: Ceiling Insulation requirements in NSW 4Oct 26, 2012 9:46 pm Your builder is bluffing you Foil backed blanket means 55mm layer of fibreglass or polyester insulation blanket adhered to reflective foil insulation Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Ceiling Insulation requirements in NSW 5Oct 27, 2012 7:46 am Thanks for your response. The foil backed blanket is already in and is not a point of contention. The "ceiling: 1.45 (up)" seems to indicate additional ceiling insulation (min R1.5) is required to comply. My argument is that inclusion of this ceiling insulation is implied as it is a BASIX requirement. This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3674 Found the answer. The recommended distance is .... 1 5989 I'm wondering if anyone knows what the requirements are of a builder to be eligible to hold Domestic Building Insurance for proposed works. https://www.dbi.vmia.vic.gov.au… 0 3335 |
