Browse Forums Building Standards; Getting It Right! 1 Mar 19, 2012 9:37 pm hi every one i am building new home and i noticed that my builder is not putting post for entry facade piller. when i asked him, he said your house doesn't need these post, because your facade is on bricks. every house i seen had those post. need suggestions. check photo link below thanks jai http://s1155.photobucket.com/albums/p55 ... 20missing/ Re: post on facade inside the piller 2Mar 22, 2012 8:38 am Not sure what the problem is that you have jai. The porch is being supported by brick pillars. An alternative would be to have posts instead of the pillars. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: post on facade inside the piller 3Mar 24, 2012 5:25 am Hi jkboora Check your approved construction drawings and see if the post is drawn in. Builder must follow the drawings. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: post on facade inside the piller 4Mar 24, 2012 10:30 am building-expert Hi jkboora Check your approved construction drawings and see if the post is drawn in. Builder must follow the drawings. Sorry b-e but your blanket statement "Builder must follow the drawings" is not correct. Plans are a guide to building the house and from memory are number 4 on the list of references to use when it comes to how to build a house. So whether a pier has a post up the middle drawn on the plan means nothing, as long as the change meets an similar standard. Cheers mgilla Re: post on facade inside the piller 5Mar 28, 2012 8:57 am mgilla building-expert Hi jkboora Check your approved construction drawings and see if the post is drawn in. Builder must follow the drawings. Sorry b-e but your blanket statement "Builder must follow the drawings" is not correct. Plans are a guide to building the house and from memory are number 4 on the list of references to use when it comes to how to build a house. So whether a pier has a post up the middle drawn on the plan means nothing, as long as the change meets an similar standard. Cheers mgilla Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: post on facade inside the piller 6Mar 28, 2012 9:03 am It is correct, If the builder does not follow the drawings he will be in breach of section 8 (a) (2) The builder warrants that the work will be carried out in accordance with the plans and specifications set out in the contract; of The Domestic Contracts Building Act. 1995 Implied Warranties. Breach of warranty is a defect: Builder cannot depart from plans without owner's consent Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: post on facade inside the piller 7Mar 28, 2012 10:52 am mgilla building-expert Hi jkboora Check your approved construction drawings and see if the post is drawn in. Builder must follow the drawings. Sorry b-e but your blanket statement "Builder must follow the drawings" is not correct. Plans are a guide to building the house and from memory are number 4 on the list of references to use when it comes to how to build a house. So whether a pier has a post up the middle drawn on the plan means nothing, as long as the change meets an similar standard. Cheers mgilla That statement is not correct. The Builder must follow the construction detailing on the endorsed drawings. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: post on facade inside the piller 8Mar 28, 2012 11:38 am Hi Peter Please elaborate your point. is your view different from mine or are you agreeing with what I said? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: post on facade inside the piller 9Mar 30, 2012 10:27 am I was agreeing. The endorsed drawings form a major part of the contract agreement & cannot be deviated from unless any (structural) alteration to the drawings are re-submitted to the BS. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: post on facade inside the piller 11Apr 12, 2012 8:47 am syber77 o BE you make me i have seen your reports there a joke to put i blunt post are normally used for OHS there is no issue Please elaborate Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog It seems very clear to me that your contract states that a security account does NOT need to be established so the answer to the builder is NO. If in doubt find a contract… 1 8505 2 31344 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4480 |
