Browse Forums Building Standards; Getting It Right! 1 Mar 02, 2012 11:33 pm I have 3-way switches in the hallway, but I'm not so sure if it's functioning as it supposed to be. (See attached plan) Here is the scenario, if I turn the lights on from the switch behind the front door, I can turn the lights on/off from the other 2 switches no dramas. If I turn them off from the switch behind the from door, I can't use the other 2 switches to turn the lights on, in other words, the switch behind the front door acts like a main power switch, turn it off will cut-off the power feed to other 2 locations. Is this how it supposed to work? I thought having 3-way switches means I can turn lights on/off from any one of those 3 location. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Sparky: 3-ways light switch Is this how it supposed to work. 2Mar 03, 2012 8:18 am Hi You are correct. You should be able to turn the lights on or off from any switch regardless of the position of the other switches. The circuits haven't been wired correctly. Paul Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1194 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3501 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10092 |
