Browse Forums Building Standards; Getting It Right! 1 Feb 15, 2012 8:47 am Hi Everyone. Was hoping if some one can shed some light on the below query. Our is a corner lot and is sloping towards the corner (or the right side of the plot). Recently we got someone to do some retaining wall at the back and the right side of the house so that we flatten it with soil. Rear Wall is done correctly but on the right side he has actually used the Fence Posts as the posts/Studs for the Timber Retaining Wall. Would this be correct ? Will this affect the fence? The timber wall is about 2 sleepers high (about 18 inches) and the will be filling the right side by about 6- 8 inches. I have still not made the final payment so would like to get some feedback if this looks correct ? 26/2 - Sales 23/3 - Colours 31/3 - Tender 14/4 - Contract 7/5 - Taps 12/6 - Site start 15/6 - Slab 27/6 - Frame 1/8 - Lockup/Fixing 29/9 - PCI 25/10 - Handover Re: Retaining Walls...Is this correct ? 2Feb 15, 2012 11:01 am I don't think I would be too happy. The posts for the fence may not be adequate for a retaining wall. The below link gives you info about what sort of posts and foundations are required; http://www.jimboombatimbers.com.au/Reta ... 0Walls.pdf The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining Walls...Is this correct ? 3Feb 15, 2012 11:30 am Any pics? Forrester 43sq We have our keys (3/6/11) Now it's time to decorate (that's the fun part.lol) https://forum.homeone.com.au/viewtopic.php?f=31&t=37598 Re: Retaining Walls...Is this correct ? 4Feb 15, 2012 8:43 pm Did more research and spoke to other ppl who have done something similar. Seems that since the Fence is fairly new and the fence posts were dug in atleast 600mm (which is the case) then this should be fine for 1-2 sleepers. Also spoke to Council Surveyor who said that this would be fine as long as I have the desired permits...(he just rambled about permits). So I am guessing this should be ok. But still want to know if anyone on H1 has had similar experience ? Thinking of adding star pickets (from bunnings for about $2) between the wall and the fence to add more strength......(got this idea from a colleague who is doing the same). what do you think....will get some pictures tomm.... 26/2 - Sales 23/3 - Colours 31/3 - Tender 14/4 - Contract 7/5 - Taps 12/6 - Site start 15/6 - Slab 27/6 - Frame 1/8 - Lockup/Fixing 29/9 - PCI 25/10 - Handover Re: Retaining Walls...Is this correct ? 6Feb 20, 2012 12:53 pm Agreed Phippsy. They are about $ 4.95 and $5.95 for the 60cm and 90 cm. we have now stained the wall this weekend. Hoping to give another coat tonight before taking some pictures 26/2 - Sales 23/3 - Colours 31/3 - Tender 14/4 - Contract 7/5 - Taps 12/6 - Site start 15/6 - Slab 27/6 - Frame 1/8 - Lockup/Fixing 29/9 - PCI 25/10 - Handover Re: Retaining Walls...Is this correct ? 7Feb 21, 2012 9:19 am Oh, and don't use a mash hammer to knock in any star pickets, use a proper star picket driver if you're doing a lot. I used a hammer years ago and busted the muscles etc in my right elbow, hasn't been any good since.... somtimes I can't lift a 2l coke bottle depending on how I'm trrying to lift it. Re: Retaining Walls...Is this correct ? 8Feb 21, 2012 11:24 am Thanks for the advice phippsy . hoping urs is not a permanent damage. 26/2 - Sales 23/3 - Colours 31/3 - Tender 14/4 - Contract 7/5 - Taps 12/6 - Site start 15/6 - Slab 27/6 - Frame 1/8 - Lockup/Fixing 29/9 - PCI 25/10 - Handover Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6057 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11108 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11758 |
