Browse Forums Building Standards; Getting It Right! 1 Dec 27, 2011 11:13 am We have a large shed with a mezzanine floor which we will use for storage etc... We have installed a staircase rather than a ladder..It has bolts into the floor and the wall etc..(so technically it could be called removable if necessary). Do we need a balustrade? It has a wall on one side all the way up, and it comes up against a wall as it gets higher on the other side. However there is an area on one side that has no balustrade etc from the floor to a height of 2.3 metres. the area to the side of this is a hall of 900m wide before the wall. To my way of thinking - if it had a ladder there would be no balustrade at all....but not sure if we need one? Re: staircase to storage area in shed- does it need a balust 2Dec 27, 2011 11:20 am For safety reasons I would want a balustrade but for ease of storing large items it could get in the way and be a pita!! Would something like a length of lightweight chain/rope/etc which is removable, work for you? Then when you want to move large, bulky items into the storage area you could temporarily remove the chain/rope/etc then refit it again later. Maybe it could be held in place with carabiners etc. All I can come up with at the moment...will be interesting to read other's suggestions. Re: staircase to storage area in shed- does it need a balust 3Dec 27, 2011 12:16 pm A potential fall of more than 2m is considered a high risk situation. If a workman or visitor to your house fell you could have a negligance claim against you. If you fell in addition to the injuries the insurer may have a get out due to negligence contributing to the injury The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Staircases and sausages. Should thou wish to keep thy palate sweet for sausages, avert thine eyes from their crafting. 14 4592 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2578 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16562 |
