Browse Forums Building Standards; Getting It Right! 1 Jul 11, 2011 10:46 am HI, Just trying to find the local authorities regualstions on earthing a steel frame house..... we are in SE Qld - so I think it would be energex, but cannot find anything on the web... any pointers...??? Re: earthing / grounding of steel frame house 2Jul 11, 2011 12:24 pm Normally you earth to the earth bar in the meter box but your supply company would be the people to ask. I would have thought you electician would know The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: earthing / grounding of steel frame house 3Jul 11, 2011 10:07 pm Is this in regard to tying the steel frame to the electrical earth? If so, AS 3000:2007 chapter 5 makes for good reading on this, it also covers tying the reinforcing mesh in the floor to the buildings earth also. This work is normally done by the electrician wiring the house, not the supply authority as it forms part of the installation. Normally what you see for earthing of a steel frame is an extra earth wire is run from the steel frame and joined into the earths of the power outlets, thats how my house is done. Re: earthing / grounding of steel frame house 4Aug 24, 2011 7:44 am Our friend is an electrical engineer who specialises in earthing so our steel frame house is earthed everywhere! As E1109 mentions we have our reinforcing mesh in the floor with a welded steel lug above slab level and the earth wire fixed to that. Apparently this prevents any corrosion and can be easily inspected. We asked our electricians if we could have as much "earthing" as possible. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14457 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8041 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8493 |
