Browse Forums Building Standards; Getting It Right! 1 Jun 26, 2011 7:00 pm Mods - If this is in the wrong section of the forum, please move it. I need help understanding this "basic" issue. What is easement? Is every stormwater pipe or sewage pipe around the house considered to be an easement?? Or is easement something much "bigger", like where main pipes from a couple of properties meet?? HELP! Once we figure what it is, then I need more help: How far from various pipes is OK to build? Or in our case, drill piers. Is it OK to drill say 0.2 meters from stormwater pipe?? My signature is distracting people from my wise posts ... What is easement?? Building next to various PIPES 2Jun 26, 2011 8:06 pm When we approached our local water authority and council they both said we could build right up to the easements on our land. HOWEVER something goes astray to the pipes below we have to wear all costs to get down to the pipes and then whatever the costs are to replace whatever we had there. The local authorities would not pay one single cent of remove / replace. In our case we chose to have one easement removed (it was never actioned, only proposed), the second we built to a metre at the closest point and the third we have nothing even close to it - simply turfed over it. Best bet is to ring the relevant authy as they all have differing rules. Personally I wouldn't go that close to any easement - the closest would be around 500mm I would even consider. Some things are worth waiting for. Re: What is easement?? Building next to various PIPES 3Jun 26, 2011 8:16 pm An easement is for a pipe owned by someone other than the householder only. So any pipes that are for your house only do not have easements. If you build on the easement you will need to get permission. Some councils and water authorities are more accommodating than other about what is allowed. You should be able to put piers within 200mm of the edge of a pipe in an an easement providing (a)the pier goes down to a level below the pipe (b) you don't damage the pipe. You will find some more info on my blog at this page. http://www.anewhouse.com.au/?p=423 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: What is easement?? Building next to various PIPES 4Jun 27, 2011 7:38 am Thanks Kyton a Bashowrth. So it seems that "easement" is not what we are dealing with, we are simply building around the sewage pipe that goes out of the house (into that easement at the back fence) BUT we seem to have a stormwater pipe as well in this area where we are building. Bash, seems like 20cm away from pipes is OK then?? My signature is distracting people from my wise posts ... Re: What is easement?? Building next to various PIPES 5Jun 27, 2011 3:32 pm If its not on the easement you can build 20cm away as long as you follow the two comments. You don't want to put load onto the pipe or otherwise damage it, as it can lead to costly problems The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: What is easement?? Building next to various PIPES 7Jun 28, 2011 8:38 pm I recently paid ( about 2 yrs) ago for an easement map from council for around $50, but found that on the website dil before you dig you can get the info emailed for free. If that help. I am in Vic... Re: What is easement?? Building next to various PIPES 8Jun 28, 2011 10:31 pm Thanks foc. Yes it's true, you can get almost all services on your land via Dial b4 u Dig, I did that before we built the house. I realised this is the so-called 'domestic infrastructure', not mains infrastructure. Easements are mains/water authority infrastructure and have different set of rules applied to them. My signature is distracting people from my wise posts ... Hi all, Looking at one lot and saw the drainage easement mentioned in contract. The easement is 6ft wide next to fence, and looks like this 1950s house already built… 0 647 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17165 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16147 |
