Browse Forums Building Standards; Getting It Right! 1 Apr 27, 2011 11:23 pm . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plastic Mains Water Pipes 2Apr 28, 2011 1:22 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Plastic Mains Water Pipes 3Apr 28, 2011 1:36 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plastic Mains Water Pipes 4Apr 28, 2011 2:52 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Plastic Mains Water Pipes 6May 10, 2011 3:35 pm . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plastic Mains Water Pipes 8Aug 31, 2011 9:57 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plastic Mains Water Pipes 9Sep 01, 2011 10:05 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plastic Mains Water Pipes 10Sep 01, 2011 10:15 am Plastic in our last 3 homes and no problems at all. Faulty workmanship is evident in ALL types of material and should be addressed at every available opportunity. As an owner, I would inspect my site every day and if not happy with the quality of instillation I would bring it up with the builder till I was satisfied. if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4215 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10891 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6426 |
