Browse Forums Building Standards; Getting It Right! 1 Apr 05, 2011 9:24 pm After 2 weeks of holidays from overseas, I was surprised to see my house going from zero to This Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think the builder was going bit too fast and decided to compromise on workmanship. After having a closer inspection of the house, I wasn't amuse anymore. The slab rebate for the brick veneer is virtually non-existence, carpenters fired nails at random, noggins were sitting over nails, and the most horrifying things are the missing sewer pipes for the toilet and basin down the slab (circled in red) , also it looks like there was fire at some stage. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm pretty sure those issues other than that shown in the last photo will be easily fixed, not so sure about the sewer pipe problem though. I have already emailed the builder about it, but would like to hear some expert here what else I can do, such as getting a engineer to have a look at the slab or something should they decided to cut open the slab? Any input will be really appreciated. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: What can you suggest? 3Apr 07, 2011 11:57 am I'm a bit perplexed about those burn marks. Are all of them up at the roof, and near where they put bolts through the metal? Maybe things got a bit too hot while drilling. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: What can you suggest? 5Apr 07, 2011 6:15 pm Aiah you may be lucky and the pipes were just cut off to low and are just under the surface of the concrete. Is it a waffle pod slab? Nope, It's a normal Raft slab. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: What can you suggest? 6Apr 07, 2011 6:21 pm Looks like it's been put up pretty quickly and poorly. For the burn marks, looks like some oxy cutting or welding occured. For the missing sewer pipes, I like Aiah's idea that they may just be slighly buried. Tap the area and hear if it sounds a bit hollower in places. Anyway, the builder will need to make good any mistakes. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: What can you suggest? 7Apr 07, 2011 6:33 pm btherl I'm a bit perplexed about those burn marks. Are all of them up at the roof, and near where they put bolts through the metal? Maybe things got a bit too hot while drilling. Pretty much everywhere there is steel joint and studs next to it, except this one looks pretty neat. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: What can you suggest? 8Apr 07, 2011 6:43 pm Casa2 For the missing sewer pipes, I like Aiah's idea that they may just be slighly buried. Tap the area and hear if it sounds a bit hollower in places. Anyway, the builder will need to make good any mistakes. I hope so. If not I'm not sure how they gonna fix it without breaking up the slab. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: What can you suggest? 9Apr 11, 2011 8:03 pm Aiah you may be lucky and the pipes were just cut off to low and are just under the surface of the concrete. Is it a waffle pod slab? Aiah, you're right, I'm being lucky this time, they were indeed buried just under the surface of the concrete. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again is this acceptable? 10May 03, 2011 12:27 am Hi guys some more questions the builders inspector doesn't seem to be too concerned about the overhanging in couple of places and told the brickie to start bricking over it. I told him it's nearly 30mm overhang, BC states 10mm tolerance, but he said its fine. What do you think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And this looks like a chippy pull this board from the mud a stick onto the wall. is this a concern or simply cosmetic issue? can it be scraped or wash down? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have yet to get my own Independent Inspector to check it out because the builder insisted the frame has not yet completed (the stacker doors to the alfresco is not put in yet) but the brickwork has already started. Should I organise an inspection now or wait for them to put that door in? I'm more concerned about the overhanging issues. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: What can you suggest? 13May 03, 2011 12:45 pm Definitely get an independent inspector - we've been using New Home Inspections (in Melbourne) for our build, had frame and pre-plaster inspections so far. The overhang doesn't seem to be much of an issue usually as they will probably just put in a thickness or two of fibre cement board (done in our case) and the pipes seem to be quite easily adjusted as well - we had a couple that actually had to be moved once the frame went up but they just broke up the concrete in the appropriate areas and extended or shortened the pvc pipes. Good luck with it all. Alamanda Point Cook (Stage 9) - Montrose 32 Our blog - http://alexandh-alamanda.blogspot.com/ Contract: 17/01/2011 Site Start: 25/02/2011 Slab: 18/03/2011 Frame: 30/03/2011 Lock-up: 21/04/2011 Re: What can you suggest? 14May 03, 2011 3:41 pm Was about to get Kevin from NHI to do a walk through before Easter but cancelled it because SS said the frame was not done. Rang Kevin again this morning and said Rob was in the area and would be happy to have a look mid day. Rob was fantastic, very thorough, picked up some issues I would never know exist. One funny thing is regarding the overhanging. The SS managed to fix the minor overhanging but leave the more serious one (30mm over) untouched and told the brickie to brick-over it. Other than some bits and pieces missing here and there, Rob rates the frame at %95 overall. The house won't collapse. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Well these guys are not looking good... I sent them a written enquiry last week and they have not yet replied. If they cannot respond to a simple… 4 10648 2 10996 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20914 |
