Hi,
I will be getting a deck (using Modwood) built over my alfresco area (currently a concrete slab). Three sides of the deck will be adjacent to the house which is brick veneer.
Approximately 1 brick up there is vertical gaps in between the bricks (these gaps appear a metre or so apart). I'm pretty sure these gaps aid in the ventilation of moisture etc.
If the decking is 14cm off the ground, approx. half of each one of these gaps will be under the deck. ie. half of the vertical gap between the bricks will be above deck and the other will be below deck.
Is there any issues with this?
We'll also be installing a strip drain on the concrete before the deck is built.
Thanks!!!!!!!!!!!!!
