Browse Forums Building Standards; Getting It Right! 1 Nov 08, 2010 9:08 pm Can anyone shed any lights? Need some clarification. Cleaing Brick, Fixing/Installing Poarch Roof, Fixing infill above window, Installing roof flushing and pointing, fixing permanent external doors, wet area tiling, bath, sink basins etc included at Fixing Stage or at Completion stage? Regards, Re: Fixing Stage Inclusion question 2Nov 08, 2010 11:32 pm Do you mean lock-up or practical completion. Re: Fixing Stage Inclusion question 4Nov 16, 2010 3:53 pm Is this for a progress claim? Brick clean can be one of the last jobs you do on a job Roof of the Porch should have been during roof cover? Roof pointing before handover - often roof companies drag their feet with this if the builder doesn't hold back enough money to get the to return. Fixing permanent external doors - often done at lockup, but if you've got expensive doors they don't want damaged then often done 2 weeks before handover. Tiling wet areas is usually after lockup and fixing, after the vanity cupboards are installed. bath, basins etc... is usually after fixings. Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11487 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 |
