Browse Forums Building Standards; Getting It Right! 1 Oct 16, 2010 6:16 pm Hi All Can anyone tell me what are allowable hole sizes that can be drilled into pine studs that are load bearing, or where I can find this information. It seems the electricians have drilled a lot of holes through studs, rather than use an extra metre of cable and run above the ceiling. A lot of holes have been drilled and haven't been used at all. Thanks Re: Hole sizes allowed in studs 2Oct 16, 2010 8:08 pm Simple terminology .... 90mm stud ... 20-25mm max hole/notch , 270mm (3x 90mm) centers between each hole/notch
If it's not to these specs don't fret, it's easily rectified with blocking. Cheers.. http://www.wespine.com.au/class1.pdf Page 9 Re: Hole sizes allowed in studs 5Oct 17, 2010 10:17 pm BCA timber framing construction specifies: Hole diameter: 25mm max, middle third of stud. Distance between holes or notches: 3x depth of stud. 20mm notches are for bracing only, except 25mm notch for bath installation. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 17374 I have a box of quality drill bits that seem to be new but their engraved sizes covered by rust ,,,,I tried to sand them to see their sizes but still I am finding… 0 850 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 3372 |
