Browse Forums Building Standards; Getting It Right! 1 Sep 25, 2010 7:38 pm Just curious, has anybody's builder done this? I just saw them on my place today, the columns are about 300mm diameter. Obviously there is a steel structural post hidden in the middle of the casing. I've never seen PVC pipe used for columns before and they have even used foam/polystyrene astragals (band at top and bottom of column). It just looks so cheap, light and fragile, not painted yet. The foam astragal (has thin epoxy coating to create a thin shell) on the ground will no doudt get damaged over time. The PVC pipe is already cracked at the top and theres a hole in it now too, but they will probably repair it. I have only ever seen compressed fibre cement used for columns before, not this crap... Re: PVC pipe used for front patio columns? 2Sep 26, 2010 5:22 pm I haven't seen this done, but had heard of it somewhere before. This website shows a similar line of products, using PVC pipe and plastic bases/tops: http://www.classiccolumn.com/ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: PVC pipe used for front patio columns? 3Oct 04, 2010 4:20 pm Your spec list should tell you all of the materials to be used. If it says cement/concrete, then get them to fix it yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7298 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 DIY, Home Maintenance & Repair Please suggest a correct way to fix this issue. I want to remove frog mouth and fix it properly because roots are getting through frog mouth and blocking pipes. I am… 0 221 |
