Browse Forums Building Standards; Getting It Right! Re: Can someone tells me this is right or wrong !!?? 4Sep 22, 2010 1:15 pm __________________________________________ Built Camberwell 29 with PD - Hand Over was on 22/12/10 http://ssazcamberwell29.blogspot.com/ Re: Can someone tells me this is right or wrong !!?? 8Nov 10, 2010 6:50 pm All plaster work and or surfaces should be viewed in natural light only (no electric lights on at all) and from a normal viewing position and also at an angle of no more than 45deg. From the pictures you have the plaster would appear to be an issue on the ceiling and cornice. Certainly the wall looks very poor, could be a board problem?? If in doubt arm yourself with a copy of the Australian Standards & tollerances book (obtainable from MBAV). All inspections will be carried out as per this guide, also all disputes will also be compared to this guide too. Good luck Re: Can someone tells me this is right or wrong !!?? 9Nov 10, 2010 8:29 pm dirkadirk All plaster work and or surfaces should be viewed in natural light only (no electric lights on at all) and from a normal viewing position and also at an angle of no more than 45deg. From the pictures you have the plaster would appear to be an issue on the ceiling and cornice. Certainly the wall looks very poor, could be a board problem?? If in doubt arm yourself with a copy of the Australian Standards & tollerances book (obtainable from MBAV). All inspections will be carried out as per this guide, also all disputes will also be compared to this guide too. Good luck Sorry, but I have to disagree with the your first statment, plaster should never look like in does in those pics. Ed already provided a link for the Australian Standards & tollerances and I provided one for Gyprock installation. Quote: All joint compound should be sanded to a smooth finish free of tool marks and ridges. Quote: It should be noted that, generally, domestic applications should be prepared to a minimum level 4 finish unless specifically a higher or lower level of finish is agreed to by all contracting parties. PAGE :13 http://www.gyprock.com.au/downloads/dow ... 0_8126.pdf Re: Can someone tells me this is right or wrong !!?? 10Nov 10, 2010 9:47 pm IMO the acute angle of the light is causing the gyprock panels to show severe but false distortion. Look at the light in the hallway... the angle would be less than 10 degrees from the sidelight of the door, you can see by the shadow of the light switch. The ceiling is the same, light globes in batten holders, producing a very acute angle from a point source. Maybe there is insufficient paint coverage on the join, that's all I can see. Judge it all in normal light... when you get your light fittings. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Can someone tells me this is right or wrong !!?? 11Nov 10, 2010 10:05 pm I'd be using a straight edge and measuring the gap (that shouldn't be there). The joints should not (when finished) be recessed at all, they should be slightly convex or totally flat. Re: Can someone tells me this is right or wrong !!?? 12Nov 15, 2010 12:00 am TheOK I'd be using a straight edge and measuring the gap (that shouldn't be there). The joints should not (when finished) be recessed at all, they should be slightly convex or totally flat. Agreed. Poor flushing. Yes the lighting accentuates it but I'd say they haven't filled it enough. I'm not sure but if the OP is in Perth then the wall surfaces will be hard plaster. If that's the case it isn't good. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Can someone tells me this is right or wrong !!?? 13Nov 16, 2010 4:10 pm It's frustrating when plasterers don't bring in portable lights to ensure walls like that don't happen. I'd be writing to the builder and asking them to address this as that is really, really poor quality. A good painter could spend some time filling and sanding that to eliminate the problem. I would emphasise that it features in your entry, so is visiably noticable to all of your guests who you proudly annouce the builder to upon their arrival. The ceiling picture is hard to see but it looks almost as if this wasn't sanded back after being filled? If that's the case, get the guys out to rectify it. Re: Can someone tells me this is right or wrong !!?? 14Dec 10, 2010 5:32 pm Builders will ALWAYS say that there's nothing wrong, by default. That's just the company policy at most building companies, if rectification is difficult. Yes, it's wrong. That is very poor trowelling, and the builder will need to rectify it, 100%. The ceilings aren't great but most ceilings in new houses show some abnormalities, especially across large spans. The finish around the cornices isn't good, but the painter should have sanded it down. If the builder was responsible for painting the ceilings then they should fix this. Re: Can someone tells me this is right or wrong !!?? 15Dec 24, 2010 12:38 pm Hi all In my opinion, the guide to standards & tolerances is quoted by the builder when they do poor work, never for good work. If your ceiling has been fixed to the bottom cord of the truss at 600 centres you will always have a bit of a wave in the plaster, seen more at night with batton lights. Because it shows the highs & lows in the surface. Even if its battened out at 400 and not lazer levelled you still will get it. The stopping up is another matter. Paint will not compensate for poor stopping up or joins. They have to be leveled filled so they are flat and or sanded back and repainted. Regardless of the Guide poor work is poor work simple as that. They may as well change it to read " all plaster joins must be viewed in the dark with both eyes closed ". Hope you get it all sorted out. Cheers KW............. “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Can someone tells me this is right or wrong !!?? 16Mar 08, 2011 2:31 am Can anyone tell me at the last picture, there are crumbled or lumpy cornice all around the house .. it started losing the edge or shape especially where the joint look not like solid anymore, anyone here please tell me .. is it a defect? what's the cause of this issue ?? the builder refused to sand it back .. Re: Can someone tells me this is right or wrong !!?? 17Mar 08, 2011 7:30 am jimsting, so the last pic does not look like that any more? It is starting to "fall apart"? If so, it's probably due to house settling. How long ago was the house finished? What soil type are you on? Can you post an updated pic? How big is the 'damage'? Our builder purposely did one particular cornice ending in a way I don't like, but the SS said it's better because future settlement cracking will be less obvious and would be easier and nicer looking after fixing than if he did it the other way. With the rest of the job, I find that pics really magnify all the issues which sometimes you wouldn't even notice with a naked eye (unless you come really close and actually look for all these untidy bits). My signature is distracting people from my wise posts ... Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 2 31344 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18298 |
