Browse Forums Building Standards; Getting It Right! 1 Sep 21, 2010 2:56 pm Hi all Just checked out my ceilling & walls like some on the forum you can see the joins. Not the most pleasing of finishes. Is it due to average workmanship or what they like to call glancing light. They look fine in day light (non critical light) but as soon as you turn on the light you can see all joins. If you to have a few problems with visable joins check this site out. Has some good info on plaster and finishes and what you can do about it. http://www.lafargeplasterboard.com.au/d ... _Light.pdf Cheers to all KW.............. “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Visable plaster joins. Why & what you can do about it. 2Sep 21, 2010 3:02 pm sounds like the paint is way too thin. Need another layers(s) Re: Visable plaster joins. Why & what you can do about it. 3Sep 21, 2010 3:21 pm Eve I think a coat more would help some for sure. However, it seems plaster is hard to get 100% smooth as the artical surgests. I did not think it was an issue many others also have. I will also try peal light globles. Most project builders will put the minimum paint on a home anyway. Cheers Kw........... “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Visable plaster joins. Why & what you can do about it. 4Sep 21, 2010 5:48 pm Hi KW, My builder actually gave me a photocopy of an article on "critical light" when I did my PCI. Basically the joints are more visible in side-on light as you have said. The article suggested the use of light shades to prevent light from going across the ceiling from the bulb (if that makes sense). Re: Visable plaster joins. Why & what you can do about it. 5Sep 22, 2010 1:43 pm Hi grom Yes, Im sure thats why some builders give you free light shades, so you dont see the plaster joins. Not much we can do about it thats dry wall plaster. The critical light factor can also show up the joins in carpet so I will plan to keep the joins away from the windows. Cheers KW................ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Visable plaster joins. Why & what you can do about it. 6Oct 01, 2010 3:23 pm Hi all Check my picture out and tell me what you think of the ceiling plaster work. Is this glancing light or just sh*t plaser work? It was taken at night under artifical light. Has anyone elles got joins like this? http://i1181.photobucket.com/albums/x43 ... C_9072.jpg Thanks Kw................. “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Visable plaster joins. Why & what you can do about it. 7Oct 01, 2010 6:03 pm King willy Hi all Check my picture out and tell me what you think of the ceiling plaster work. Is this glancing light or just sh*t plaser work? It was taken at night under artifical light. Has anyone elles got joins like this? http://i1181.photobucket.com/albums/x43 ... C_9072.jpg Thanks Kw................. Sh*t palstering Re: Visable plaster joins. Why & what you can do about it. 8Oct 01, 2010 6:49 pm Hi, My other half is a plasterer and I can safely say that is very sh*t plastering. Ask the builder to get the plasterers back to fix immediately!! Re: Visable plaster joins. Why & what you can do about it. 10Oct 01, 2010 10:57 pm What they said that is I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Visable plaster joins. Why & what you can do about it. 11Oct 01, 2010 11:37 pm Ours is not as prominent as yours, but almost. But I only noticed it after I changed our shades from the chinamen hat shades. I've brought it up with our builder, and the response is basically, yeah, you get that. They really brush it off and they won't fix it. My peeve is more with the little patch up jobs here and there where tradies have taken chunks out with ladders or tools, then the site supervisor patched it up. Bless his cotton socks, but it looks like crap Dear J.K. Rowling, Your books are entirely unrealistic. I mean, a ginger kid with two friends? Sincerely, Anonymous Re: Visable plaster joins. Why & what you can do about it. 12Oct 03, 2010 9:16 am King willy Hi all Check my picture out and tell me what you think of the ceiling plaster work. Is this glancing light or just sh*t plaser work? It was taken at night under artifical light. Has anyone elles got joins like this? http://i1181.photobucket.com/albums/x43 ... C_9072.jpg Thanks Kw................. They have only done a base coat, to set the paper tape. There should be another 2 coats ontop of that! Re: Visable plaster joins. Why & what you can do about it. 13Oct 03, 2010 1:16 pm Hi all Thanks for your kind replies. The problem is you can only see it at night time, its not visable in day light. Its a real pain and a dissapointment. Its a bit hard to show the builder in day light. I guess I can show him the photos. KW................ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Visable plaster joins. Why & what you can do about it. 14Oct 03, 2010 1:53 pm Place a 600mm straight edge (300mm either side) over the join and measure the gap between the join to the straight edge.
EDIT page 37 ... http://www.gyprock.com.au/downloads/dow ... 0_8126.pdf Re: Visable plaster joins. Why & what you can do about it. 15Oct 03, 2010 2:01 pm Yep,carpy job ,we did better ourselves with our reno It does look like they have not filled it in properly, tape/fill/sand,fill/sand,fill/sand well thats what we did anyway. One of the houses we are looking at "Promises that you will have not joins showing",will be interesting to see the end result. Get them to fix it,good luck!! Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5025 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5295 Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 13487 |
