Browse Forums Building Standards; Getting It Right! 1 Sep 05, 2010 4:45 pm Since we've moved in, our son has been complaining of a rattling noise coming from the window when it's windy. We initially thought it was the fly screen and did everything we could do to secure it but the noise has persisted. At our 3 month inspection....we pointed it out to PD inspector and again nothing they could do. This noise has been driving my son insane as it is right next to his head when he sleeps. It is annoying him so much so that at times he can't sleep well at all. The other night we finally worked out that it is the insulation foil/sarking that is causing this noise and he's right....it's fricking annoying!!! What can we do??? Can we still get PD to fix this? The outside of his wall is weatherboard...so they wouldn't need to break any bricks. Pls help. Our building journey has begun: https://forum.homeone.com.au/viewtopic.php?f=31&t=23138 Brookvale 45 by Porter Davis ************** Lead me not into temptation.....I can find the way myself. Re: Sarking/insulation foil flapping in the wind - HELP 2Sep 05, 2010 5:23 pm overwhelmed Since we've moved in, our son has been complaining of a rattling noise coming from the window when it's windy. We initially thought it was the fly screen and did everything we could do to secure it but the noise has persisted. At our 3 month inspection....we pointed it out to PD inspector and again nothing they could do. This noise has been driving my son insane as it is right next to his head when he sleeps. It is annoying him so much so that at times he can't sleep well at all. The other night we finally worked out that it is the insulation foil/sarking that is causing this noise and he's right....it's fricking annoying!!! What can we do??? Can we still get PD to fix this? The outside of his wall is weatherboard...so they wouldn't need to break any bricks. Pls help. Now you know the cause and where it's located they should come back and rectify the problem. Sounds like you need to gap seal @ the architrave/weatherboards ..is there a gap? Re: Sarking/insulation foil flapping in the wind - HELP 3Sep 05, 2010 8:06 pm We have the same issue and PD will fix it. I don't want the bricks pulled down as it is on our facade, so they can come in from the inside wall and go through the plaster. As it is highly unlikely it will be windy when someone comes out to check, film it on your phone so they can hear how loud it is. That's what I did. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Sarking/insulation foil flapping in the wind - HELP 4Sep 07, 2010 12:15 pm joles We have the same issue and PD will fix it. I don't want the bricks pulled down as it is on our facade, so they can come in from the inside wall and go through the plaster. As it is highly unlikely it will be windy when someone comes out to check, film it on your phone so they can hear how loud it is. That's what I did. I am wondering how they want to fix the insulation foil properly on the outside of the frame when coming from inside? Cheers Christian Re: Sarking/insulation foil flapping in the wind - HELP 5Sep 07, 2010 6:39 pm cwoern joles We have the same issue and PD will fix it. I don't want the bricks pulled down as it is on our facade, so they can come in from the inside wall and go through the plaster. As it is highly unlikely it will be windy when someone comes out to check, film it on your phone so they can hear how loud it is. That's what I did. I am wondering how they want to fix the insulation foil properly on the outside of the frame when coming from inside? Cheers Christian They'll probably use an 'expanding spray foam'. ..that's how I'd tackle it, stickier than s**t to a blanket and will get into every nook and cranny. Re: Sarking/insulation foil flapping in the wind - HELP 6Sep 08, 2010 1:41 pm overwhelmed Since we've moved in, our son has been complaining of a rattling noise coming from the window when it's windy. We initially thought it was the fly screen and did everything we could do to secure it but the noise has persisted. At our 3 month inspection....we pointed it out to PD inspector and again nothing they could do. This noise has been driving my son insane as it is right next to his head when he sleeps. It is annoying him so much so that at times he can't sleep well at all. The other night we finally worked out that it is the insulation foil/sarking that is causing this noise and he's right....it's fricking annoying!!! What can we do??? Can we still get PD to fix this? The outside of his wall is weatherboard...so they wouldn't need to break any bricks. Pls help. Hi overwhelmed, I'm sorry to hear that this noise is annoying your son so much, it should be attended too. At this stage, your New Home Care Coordinator is your point of contact for any concerns you may have. I recommend giving them a call to organise repairs. If you don't have a way to contact them, you can send me a private message with your name, address and number and we'll do our best to get in contact with you. I hope this helps you out. Cheers, Jess. Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Sarking/insulation foil flapping in the wind - HELP 7Sep 09, 2010 1:30 pm It would be extremely improbable for the RFL to be vibrating to any extent beneath a weatherboard cladding. PD have made the offer via Jess to rectify the problem. Let us know the outcome of their investigation. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Sarking/insulation foil flapping in the wind - HELP 8Oct 06, 2010 10:10 am overwhelmed Since we've moved in, our son has been complaining of a rattling noise coming from the window when it's windy. We initially thought it was the fly screen and did everything we could do to secure it but the noise has persisted. At our 3 month inspection....we pointed it out to PD inspector and again nothing they could do. This noise has been driving my son insane as it is right next to his head when he sleeps. It is annoying him so much so that at times he can't sleep well at all. The other night we finally worked out that it is the insulation foil/sarking that is causing this noise and he's right....it's fricking annoying!!! What can we do??? Can we still get PD to fix this? The outside of his wall is weatherboard...so they wouldn't need to break any bricks. Pls help. Hi Overwhelmed, I never received a PM with your details, how is everything going? Have you spoken to anyone at Porter Davis about the rattling noise in the insulation? Let me know how you go, or send me through your details and I'll see if I can get things moving for you. Cheers, Jess. Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Sarking/insulation foil flapping in the wind - HELP 9Oct 06, 2010 11:44 am Wow guys I sent a pm about an hour ago to Jess because I have a similar sort of noise even though I am not 100% sure whether it comes from the insulation. I was actually in the same situation like you "overwhelmed" where my 3 months inspection went past and I only picked that noise up recently but now I am quite happy that I got a call from my maintenance officer and she is organising in sending someone out to look at it. I am so relieved now and impressed with the fast turn around. =-) I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17047 Building Standards; Getting It Right! Hi all Iām in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 11713 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11273 |
