Browse Forums Building Standards; Getting It Right! Re: Eave board vibrates/ makes noise in high wind 3Aug 29, 2010 10:50 am If it's on a brick veneer construction with the eave sheet sitting on the brick then it could be at that point due to lack of fixing to trimmers. In any case it sounds like it may be due to insufficient nailing to trimmers - which I would deem as unacceptable. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 3283 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11784 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11664 |
