Browse Forums Building Standards; Getting It Right! 1 May 31, 2010 8:04 pm Guys, Need Information from guys who has their plans approved... We are building a SIngle storey house at the ponds as we have a narrow fronatge just want to check the Min Distance we need to leave... The Minimum distance I need to leave between my Fence and Brick wall is 900 mm and the eves can come off the Brick by 450mm, thereby the distance between fence and eaves would be 450mm. Distance between brick and fence is 900mm Minimum Eaves required under Ponds is 450mm Hence the Distance between Eaves and Fence would then be 450mm (Is it aceptable and if any of you got this approved). Thanks in Advance Red 2 7534 Found the answer. The recommended distance is .... 1 5982 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5870 |
